Hi
I am cleaning up my HD. There are 2 AutoCAD LT versions installed.
Should I remove old version ?
Is it will effect any customization setting I set in old version 2021 before upgrading to 2022 ?
or Should I leave old version like this if it is not take too much HD space ?
Thank you very much
Hi @kwinRUVCL,
If you've transferred any settings across then they won't affect 2022. However, if you still work with people who still run AutoCAD 2021 it may be worth keeping around for compatibility (AutoCAD isn't my speciality). Otherwise, you can delete it with no issues as you can just get the installer from your account if you need it.
