Revit - Slow Sync Process
Hello All!
I was hoping to get some feedback on an issue our end-users are experiencing. As they are currently utilizing Revit 2015 and will eventually move on to the latest versions of Revit, AutoCAD, etc., they are having slow sync issues with their Central Models located on our local File Server. They would work off their local model and sync to the Central Model on the shared drives(Located on the File Server) every 30 minutes, which is recommended. This sync process to the Central Model usually takes between 3-5 minutes, of course depending on the changes and file size. In this case, one example would be a 500MB Revit model. When they sync to the local model, it takes less than 30-45 seconds. I am hoping to upgrade their File Server to improve this sync process as well as ugprading their pipeline from a 1G to 10G NICs. I do not think it is so much their workstations as they are powerhouse computers.
End-User Computer Specs:
HP Z620 with 32/40GB Xeon E5-1650 v2 @3.50ghz
1Gig NIC
500GB SSD Samsung 840PRO
Server 2008 R2 Standard
HP ProLiant DL380 G3
2x CPU Xeon X5355 2.66ghz
4GB of RAM
Any suggestions or ideas? Is the server the bottleneck? Server upgrade suggestions?
