Solved by natasha.l. Go to Solution.
Hello @roscopeco2000,
Welcome back.
What Revit 2019 update are you trying to apply? There are extensions & add-ins for Revit 2019.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thank you for your patience, I would continue to check directly in your Autodesk Account it should be available soon. Not all users have received the new release rollouts yet & the information on when is not provided.
Natasha
Helpful Links:
I understand that you are a student?
In that case, you need to select the 2019 version from the educational community "Free Software" page. The product will appear in your Autodesk Account in 24-48hrs after you select it from the drop-downs.
Let me know how it turned out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Helpful Links:
