Installation & Licensing
Revit installation error windows 10
6 REPLIES 6
880 Views, 6 Replies
Could you help me? i tried to intall autodesk revit 2015 but after a few second of installation it says error
there is the error log
2016/2/13:23:30:33 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:30:33 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:30:33 Marcin DESKTOP-QB55TLI Current Directory C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm
2016/2/13:23:30:33 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:30:33 Marcin DESKTOP-QB55TLI CommandLine
2016/2/13:23:30:33 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AIADDE.tmp
2016/2/13:23:30:50 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:30:40 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:30:40 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:30:40 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AIADDE.tmp
2016/2/13:23:30:40 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:30:42 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AIADDE.tmp\Setup\RevitSetup.dll
2016/2/13:23:30:42 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/13:23:30:45 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AIADDE.tmp\Setup\RevitSetup.dll
2016/2/13:23:30:45 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Usunięcie zaznaczenia instalacji zawartości ma wpływ na krytyczne ustawienia programu Autodesk® Revit® 2015. URLTitle= URLLink=
2016/2/13:23:30:51 Marcin DESKTOP-QB55TLI PageOpen LaunchDialog
2016/2/13:23:30:55 Marcin DESKTOP-QB55TLI PageOpen LicenseDialog
2016/2/13:23:30:58 Marcin DESKTOP-QB55TLI PageOpen ProductInfoDialog
2016/2/13:23:32:30 Marcin DESKTOP-QB55TLI PageOpen ProductSelectionDialog2
2016/2/13:23:33:09 Marcin DESKTOP-QB55TLI PageOpen FullProgressDialog
2016/2/13:23:33:10 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/2/13:23:33:33 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2016/2/13:23:33:33 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Marcin\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/13:23:33:39 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/2/13:23:33:39 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Marcin\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/2/13:23:33:44 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2016/2/13:23:33:44 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2016/2/13:23:34:01 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2016/2/13:23:34:01 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/2/13:23:34:02 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2016/2/13:23:34:02 Marcin DESKTOP-QB55TLI Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/13:23:34:02 Marcin DESKTOP-QB55TLI Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/13:23:34:03 Marcin DESKTOP-QB55TLI PageOpen InstallCompleteDialog
2016/2/13:23:34:19 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:35:24 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:35:24 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:35:24 Marcin DESKTOP-QB55TLI Current Directory C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm
2016/2/13:23:35:24 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:35:24 Marcin DESKTOP-QB55TLI CommandLine
2016/2/13:23:35:24 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI2220.tmp
2016/2/13:23:35:29 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:35:27 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:35:27 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:35:27 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI2220.tmp
2016/2/13:23:35:27 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:35:27 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI2220.tmp\Setup\RevitSetup.dll
2016/2/13:23:35:27 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/13:23:35:29 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI2220.tmp\Setup\RevitSetup.dll
2016/2/13:23:35:29 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Usunięcie zaznaczenia instalacji zawartości ma wpływ na krytyczne ustawienia programu Autodesk® Revit® 2015. URLTitle= URLLink=
2016/2/13:23:35:29 Marcin DESKTOP-QB55TLI PageOpen LaunchDialog
2016/2/13:23:35:31 Marcin DESKTOP-QB55TLI PageOpen LicenseDialog
2016/2/13:23:35:33 Marcin DESKTOP-QB55TLI PageOpen ProductInfoDialog
2016/2/13:23:36:25 Marcin DESKTOP-QB55TLI PageOpen ProductSelectionDialog2
2016/2/13:23:37:29 Marcin DESKTOP-QB55TLI PageOpen FullProgressDialog
2016/2/13:23:37:29 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/2/13:23:37:29 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2016/2/13:23:37:30 Marcin DESKTOP-QB55TLI PageOpen InstallCompleteDialog
2016/2/13:23:37:47 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:44:04 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:44:04 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:44:04 Marcin DESKTOP-QB55TLI Current Directory C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm
2016/2/13:23:44:04 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:44:04 Marcin DESKTOP-QB55TLI CommandLine
2016/2/13:23:44:04 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI1354.tmp
2016/2/13:23:44:08 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:44:06 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:44:06 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:44:06 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI1354.tmp
2016/2/13:23:44:06 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:44:06 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI1354.tmp\Setup\RevitSetup.dll
2016/2/13:23:44:06 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/13:23:44:08 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI1354.tmp\Setup\RevitSetup.dll
2016/2/13:23:44:08 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Usunięcie zaznaczenia instalacji zawartości ma wpływ na krytyczne ustawienia programu Autodesk® Revit® 2015. URLTitle= URLLink=
2016/2/13:23:44:08 Marcin DESKTOP-QB55TLI PageOpen LaunchDialog
2016/2/13:23:44:15 Marcin DESKTOP-QB55TLI PageOpen LicenseDialog
2016/2/13:23:44:17 Marcin DESKTOP-QB55TLI PageOpen ProductInfoDialog
2016/2/13:23:45:18 Marcin DESKTOP-QB55TLI PageOpen ProductSelectionDialog2
2016/2/13:23:45:38 Marcin DESKTOP-QB55TLI PageOpen FullProgressDialog
2016/2/13:23:45:39 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/2/13:23:45:39 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2016/2/13:23:45:40 Marcin DESKTOP-QB55TLI PageOpen InstallCompleteDialog
2016/2/13:23:46:23 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:46:50 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:46:50 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:46:50 Marcin DESKTOP-QB55TLI Current Directory C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm
2016/2/13:23:46:50 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:46:50 Marcin DESKTOP-QB55TLI CommandLine
2016/2/13:23:46:50 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI9A3E.tmp
2016/2/13:23:46:58 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/13:23:46:55 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/13:23:46:55 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/13:23:46:55 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI9A3E.tmp
2016/2/13:23:46:55 Marcin DESKTOP-QB55TLI Launch
2016/2/13:23:46:55 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI9A3E.tmp\Setup\RevitSetup.dll
2016/2/13:23:46:55 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/13:23:46:58 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI9A3E.tmp\Setup\RevitSetup.dll
2016/2/13:23:46:58 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Usunięcie zaznaczenia instalacji zawartości ma wpływ na krytyczne ustawienia programu Autodesk® Revit® 2015. URLTitle= URLLink=
2016/2/13:23:46:59 Marcin DESKTOP-QB55TLI PageOpen LaunchDialog
2016/2/13:23:48:52 Marcin DESKTOP-QB55TLI PageOpen LicenseDialog
2016/2/13:23:48:54 Marcin DESKTOP-QB55TLI PageOpen ProductInfoDialog
2016/2/13:23:49:47 Marcin DESKTOP-QB55TLI PageOpen ProductSelectionDialog2
2016/2/13:23:49:53 Marcin DESKTOP-QB55TLI PageOpen FullProgressDialog
2016/2/13:23:49:53 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/2/13:23:49:54 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2016/2/13:23:49:55 Marcin DESKTOP-QB55TLI PageOpen InstallCompleteDialog
2016/2/13:23:50:03 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/14:17:56:25 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/14:17:56:25 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/14:17:56:25 Marcin DESKTOP-QB55TLI Current Directory C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm
2016/2/14:17:56:25 Marcin DESKTOP-QB55TLI Launch
2016/2/14:17:56:25 Marcin DESKTOP-QB55TLI CommandLine
2016/2/14:17:56:25 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI273A.tmp
2016/2/14:17:56:33 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/14:17:56:28 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/14:17:56:28 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/14:17:56:28 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AI273A.tmp
2016/2/14:17:56:28 Marcin DESKTOP-QB55TLI Launch
2016/2/14:17:56:29 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI273A.tmp\Setup\RevitSetup.dll
2016/2/14:17:56:29 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/14:17:56:33 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AI273A.tmp\Setup\RevitSetup.dll
2016/2/14:17:56:33 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Usunięcie zaznaczenia instalacji zawartości ma wpływ na krytyczne ustawienia programu Autodesk® Revit® 2015. URLTitle= URLLink=
2016/2/14:17:56:33 Marcin DESKTOP-QB55TLI PageOpen LaunchDialog
2016/2/14:17:56:36 Marcin DESKTOP-QB55TLI PageOpen LicenseDialog
2016/2/14:17:56:38 Marcin DESKTOP-QB55TLI PageOpen ProductInfoDialog
2016/2/14:17:58:06 Marcin DESKTOP-QB55TLI PageOpen ProductSelectionDialog2
2016/2/14:17:58:50 Marcin DESKTOP-QB55TLI PageOpen FullProgressDialog
2016/2/14:17:58:50 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/2/14:17:58:50 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2016/2/14:17:58:51 Marcin DESKTOP-QB55TLI PageOpen InstallCompleteDialog
2016/2/14:17:59:48 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/14:18:02:38 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/14:18:02:38 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/14:18:02:38 Marcin DESKTOP-QB55TLI Current Directory C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm
2016/2/14:18:02:38 Marcin DESKTOP-QB55TLI Launch
2016/2/14:18:02:38 Marcin DESKTOP-QB55TLI CommandLine
2016/2/14:18:02:38 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AID6CB.tmp
2016/2/14:18:02:41 Marcin DESKTOP-QB55TLI === Setup ended ===
2016/2/14:18:02:39 Marcin DESKTOP-QB55TLI === Setup started on DESKTOP-QB55TLI by Marcin ===
2016/2/14:18:02:39 Marcin DESKTOP-QB55TLI Path_Length: 155
2016/2/14:18:02:39 Marcin DESKTOP-QB55TLI Current Directory C:\Users\Marcin\AppData\Local\Temp\_AID6CB.tmp
2016/2/14:18:02:39 Marcin DESKTOP-QB55TLI Launch
2016/2/14:18:02:39 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AID6CB.tmp\Setup\RevitSetup.dll
2016/2/14:18:02:39 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/14:18:02:40 Marcin DESKTOP-QB55TLI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Marcin\AppData\Local\Temp\_AID6CB.tmp\Setup\RevitSetup.dll
2016/2/14:18:02:40 Marcin DESKTOP-QB55TLI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Usunięcie zaznaczenia instalacji zawartości ma wpływ na krytyczne ustawienia programu Autodesk® Revit® 2015. URLTitle= URLLink=
2016/2/14:18:02:40 Marcin DESKTOP-QB55TLI PageOpen LaunchDialog
2016/2/14:18:02:42 Marcin DESKTOP-QB55TLI PageOpen LicenseDialog
2016/2/14:18:02:44 Marcin DESKTOP-QB55TLI PageOpen ProductInfoDialog
2016/2/14:18:03:45 Marcin DESKTOP-QB55TLI PageOpen ProductSelectionDialog2
2016/2/14:18:04:05 Marcin DESKTOP-QB55TLI PageOpen FullProgressDialog
2016/2/14:18:04:05 Marcin DESKTOP-QB55TLI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Polish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/2/14:18:04:06 Marcin DESKTOP-QB55TLI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
6 REPLIES 6
Otto
Hello Shyat and welcome to the Autodesk community!
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
RDAOU
From your report it appears that your installation session was ended and restarted several times. You can try the following:
A. Disable any running antivirus, antispam and firewall 3rd party softwares (as well as windows defender if you have it on)
B. Make sure that you have admin privilages to install softwares
C. Download the software from the Autodesk Virtual Agent <-- (click on Download Links, choose product and version). Then try the installation again.
Alternatively:
When you installed Autodesk Revit 2015/2016 Educational version from Autodesk website...After you select Revit version, Operating system and language; there should be below a drop down menu with 3 possible options to aquire the software (Install/Download/Browser Download) I would recommend to use Browser Download. You will get successively 2 files (4.5 Gb) to install on your loacl drive which after download you need to uncompress both in one folder then use the Setup.exe
I have tried this several times and it works perfectly fine when the other two options and virtual agent did not work. It even gets all Libraries and Template files which many are experiencing problems downloading.
More info on Browser Download can be found HERE
If the above works please come back here and report success by accepting this reply as a Solution
in reply to: RDAOU
Hmm still the same ;s
Im always download it by browser downloader
I also tried to disable all antivirus etc and download by Agent but still and still the same error ;d
Yesterday i installed AutoCad 2015 and Civil without any problems
RDAOU
Can you go to Control Panel > Programs and Features  Uninstall it from there completely then do a clean installation?
jgernand
Don't know if you've already got this to work, but i finally did. You have to disable popup blocker. then download each program individually. Max/ Maya and when downloading use the drop down menu next to install now and select browser download. The issue is the install wizard for Autodesk is not compatable with windows 10. This way of doing it will download all files necessary to install so the installer doesn't crash like normal. At least it worked for me. Also you will need to be at the computer for most of it because it downloads two separate files before it will work. Basically you should have to hit run twice. If you haven't gotten at least two pop ups you're doing something wrong. Anyway, hope this helps 🙂
Tags (1)
Windows 10 is not yet an officially supported operating system across the Autodesk product line. Autodesk intends to support many of our key products on Windows 10 and will add products to the list of products supported on Windows 10 as updates and future versions are released. The most common issue is the inability to do a new installation of an Autodesk product on a Windows 10 operating system due to the Windows 10 reliance on .NET 4.6. In most cases, Autodesk products installed on an earlier operating system that was later upgraded to Windows 10 will continue to work as expected. Many of these issues have been corrected by the most recent Windows 10 updates. Update your Windows 10 installation to receive the latest updates.
Install Service Pack 1 and Service Pack 2 found here: All Revit Updates and make sure your graphics card has been tested or just turn it off for right now. How to do this can be found here: Revit Hardware acceleration.
On your operating system you will need to change the text size if you are experiencing extremely large text.
On the start menu type SETTINGS in the search applications. Click on Device then click on Display.
Set the "Change the size of text, apps, and other items" to 100%
Reboot your machine and see if this fixes your display issues.
Administrator Productivity
