Installation & Licensing
REVIT ARCHITECTURE 2011 ACTIVATION ISSUE
7 REPLIES 7
Message 1 of 8
4630 Views, 7 Replies
I HAVE REVIT ARCH 2011 INSTALLED AND WORKING UNDER DEMO MODE........i would like to convert it into  fully functional mode...could some one plz guide me through the process for a standalone installation.....i am using revit on my laptop for academic purpose...
I have read through the remedy posted by you guys to solve netwrok license issues....is it the same for a standalone license as well......??
my revit 2011 gives an error while start up...the error is "cant obtain a license" & and the next message says "revit is running in idemo mode"....the register button in the licensing window doesnt seem to work [nothing happens when i click on it].....
so how do i acivate it????
will appreciate ur help.........
7 REPLIES 7
Message 2 of 8
hashim.mundol
hashim.mundol
Autodesk Support
Autodesk Support
Please try to activate within the product (help->about->Product information->Activate)
If you still have issues
Active scripting might be disabled,please try  below solution
http://usa.autodesk.com/getdoc/id=TS1053941
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Hashim Mundol
Message 3 of 8
the solution you provided doesnt help........the same messages appear even when i try to activate the product through help-about-product information-[i dont get  an activation link or tab]....is there anything else i can do...i am at the end of my semester and need revit to be functioning badly......
Message 4 of 8
hashim.mundol
hashim.mundol
Autodesk Support
Autodesk Support
Please delete the license file, this file contains license for all the autodesk 2010/2011 products, if you have any other products this will force others to be re-activated too.
on vista/win7
%programdata%\flexnet\adsk*.data
xp
C:\Documents and Settings\All Users\Application Data\flexnet\adsk*.data
if this doenst work. please try a reinstall of the Software
Hashim Mundol
on vista/win7
xp
Hashim Mundol
Message 5 of 8
in reply to: hashim.mundol
Thanks ....it worked finally.....
Message 6 of 8
I've also tried to adjust the registry values however I cannot find the %programdata%\flexnet\adsk*.data file you suggested. I'm using windows vista and I'm having the same issue with the activation page after clicking activate.
Message 7 of 8
In order to find the license file first enable the "view hidden files" options from the tools menu in windows explorer...u will be able to find the folder called program data only then.......then proceed as directed
Message 8 of 8
The same situation happened on my computer. I am using WINDOWS 7 system.I have operated the steps you mentioned in terms of the win2000/xp or Vista, but it did NOT work. So how to solve this issue on Win7 environment? Thankds.
Hao
Hao
Administrator Productivity
