Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Revit 2024: "Failed to initialize DownloadManager!"
walter_beamer
Message 1 of 21
walter_beamer
I am attempting to install Revit 2024. I downloaded the Autodesk_Revit_2024_CWB_install.exe file and double clicked it which from what I can understand is meant to run the Autodesk Create Installer, but instead I get a "Failed to initialize DownloadManager!" error and the process stops.
What are the next steps required to get this issue resolved?
Replies (20)
Message 2 of 21
Message 3 of 21
walter_beamer
The above link does not resolve my issue. The Autodesk Access Service Host is running on my system and I still get the same "Failed to initialize DownloadManager!" error.
Message 4 of 21
walter_beamer
It should be noted that the above described issue occurs when I try to use the following file:
Create_Installer_RVT_2024_English_WIN64.exe
If I try to use the Autodesk_Revit_2024_ML_setup_webinstall.exe file I get a "7-Zip Error".
I have consulted with the 7-Zip Error thread on the forum, but none of it seems applicable to my issue.
Message 6 of 21
walter_beamer
The links in the above reply reference P1,P2,P3,P4,P5, but the files are P1(x4) and P5. Can you please resend p2-p4?
Message 8 of 21
walter_beamer
Hi Mike, Thanks for the revised link. I downloaded all 5 of the files and then ran #1. It failed to get past 3% and ended with an Install error, Error-9.
The "How do I fix this?" link is broken and leads to a 404 Error
Am I doing something wrong? Any other ideas?
Message 9 of 21
mdavis22569
That sounds like a missing Windows update:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-install-couldn...
Any pending updates? What's the current build of Windows? Can you share the Winver?
Mike Davis
Message 10 of 21
walter_beamer
Windows Update says I'm current.
I'm running Windows 10 Pro Ver 22H2 Build 19045.3570
Message 11 of 21
mdavis22569
I'm still looking at something PC related .. I use those installers (as do others) numerous times a week if not numerous times daily.
Nothing wrong with those installers.
So we need to go backwards:
Let's clean out the %temp% folder.
Let's run the Microsoft FixIt tool ..
Maybe a new Windows Temporary profile
Mike Davis
Message 12 of 21
walter_beamer
I am not familiar with the Microsoft FixIt tool.
Message 13 of 21
mdavis22569
https://support.microsoft.com/en-gb/topic/fix-problems-that-block-programs-from-being-installed-or-r...
Mike Davis
Message 14 of 21
walter_beamer
The Troubleshooting program was not able to identify the issue.
Message 15 of 21
mdavis22569
Let it finish .. and then retry.
Delete everything prior from C:\Autodesk
Clean out the %temp% folder
Clean out the C:\download except for the 5 downloads.  Re-extract it.
I'd consider a different Windows profile to test too.
Mike Davis
Message 16 of 21
walter_beamer
Mike,
Can you please clarify what is intended by %temp% folder? Is it the C:\Windows\Temp or the
C:\Users\profile\AppData\Local\Temp folder or something else?
Message 17 of 21
mdavis22569
put %temp% in the Windows Explorer and it'll bring it up
or put it in the Search for the Windows box.
Mike Davis
Message 18 of 21
walter_beamer
I Deleted everything in the C:\Autodesk Folder
I Deleted everything in the %temp% folder
I Deleted everything in C:\download and then redownloaded the 5 downloads.
I Re-extract the installer by clicking on file 1 of 5 and it extracted everything into C:\Autodesk\Revit_2024_G1_Win_64bit_dlm and the installer began.
It again failed and presents the Install Error -9 message as it did above.
What else can be done?
Message 19 of 21
pendean
Community Legend
Community Legend
@walter_beamer logout as you then log back into your PC as an all-new user with full admin rights.
When you are ready to install the software, right-click on the first installer file you downloaded and select RUN AS ADMINISTRATOR.
Best of luck.
Message 20 of 21
walter_beamer
That finally did it. Thank you.
