Installation & Licensing
Revit 2024.2 install failing - no access to cloud models?
3 REPLIES 3
cadfmconsultants
230 Views, 3 Replies
I am trying my hardest to re-install Revit 2024. It has installed EASILY until this particular update of 2024.2 is included in the install. Yes, I have done everything it suggests. Yes, I have cleared the registry. On my seventh attempt and monitors close to going out of the window. Anyone else had this issue?
Shaun 'CADjedi' Bryant
AutoCAD and Revit ACI and occasional Tinkercad user
Not Just CAD! - The Official Blog of CADFMconsultants
Twitter | LinkedIn
Tags (2)
3 REPLIES 3
Hi Shaun
The could not access network location error is a good indication that some remnants from a previous installation remain on this system.  I would recommend uninstalling Revit 2024 using the traditional add/remove programs workflow.  Then manually delete any of the following registry keys that were not removed by the uninstall process:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\{29B0C913-DAF1-4152-8AE7-A3623A1D4AA0}
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\{484ACE17-2EBF-3D83-AB9B-E0B4EFD8DC62}
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\{63F8F057-85FB-337D-8493-CD003BAEAC52}
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\{6BB52C99-5323-333D-A7E9-D4111DE809FC}
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\{E38A303B-2722-39DE-A741-E841A50C62FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features\0A4B643700420150000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Patches\B9B50AC9204201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Patches\B9B50AC9304201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Patches\B9B50AC9404201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Patches\B9B50AC9504201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\0A4B643700420150000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\UpgradeCodes\1A4B643700420150000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Patches\B9B50AC9204201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Patches\B9B50AC9304201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Patches\B9B50AC9404201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Patches\B9B50AC9504201501A4BFF7F6A08EF55
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\0A4B643700420150000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{15E35943-74DB-3938-8C8D-3A68E74001BF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{49A82B2D-DA3A-36FB-88CD-1B45776FFD21}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7346B4A0-2400-0510-0000-705C0D862004}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A3A5733-181A-3FAE-902A-CA01EEE1A2FD}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B6BF3582-6DA2-30C2-9699-A097A91AA967}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FCEB3AFE-37D5-362D-8764-9037B5EC6764}
This should leave your system in a clean state where Revit 2024 and the 2024.2 update can be installed successfully.
Anthony Michniewicz
Principal QA Analyst
Thanks for this. I will try this out later this evening. Stay tuned!
Twitter | LinkedIn
Don't have a solution for your problem but I wonder - I regularly see forum posts of Expert Elite Members. I thought they would have a more direct way to contact Autodesk support persons?
Administrator Productivity
