'Revit 2023.1.1 Update' will not install.
Try 1. I also tried uninstalling and reinstalling.
try 2. Updated from Autodesk App.
try 3. I also tried downloading a custom installer.
All three of the above attempts do not work. Current version is 23.0.20.21 with hotfix installed. How can I update to 2023.1.1?
Solved by m_latz. Go to Solution.
Solved by DarrenP. Go to Solution.
No error message?
Like 101 for example
Sebastian
Hi @ttooc2
Thanks a lot for posting your question to the forums!
For the community to help you best, it would be great to have more details from your end.
• Any error messages showing the install fail
• If possible, can you add screenshots or attach a video showing the issue? Info on how to add a video can be found here.
I look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
another thread on this: https://forums.autodesk.com/t5/installation-licensing/revit-2023-1-instalation-error/td-p/11559113
DarrenP
