I'm trying to install revit 2022 and keep receiving this msg when extracting the file. local IT doesn't know what to do with this but I can download other autodesk products so it shouldnt be a firewall issue. please advise
Solved by handjonathan. Go to Solution.
Hi @King_ChengD6DTN
Thanks a lot for posting your question to the forums! Please see below for potential cases and fixes:
Note. Make sure you have uninstalled and reinstalled the ODIS component as per the first suggestion.
If this doesn't work, use the Microsoft Fix It tool to remove the software.
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Change your download method to the full download .. (offline / Browser one) and then do it
