REVIT 2021 LICENSING ERROR
hallalleon
hallalleon
Hey folks, I downloaded revit 2021 but failed to open when signing in
gave me the licensing error, now I've looked through several ways even contacted autodesk but in vain at least till now
after downloading the autodesk server license, i tried to install it but it never opens
i'd be glad if someone could help
uninstalling doesn't help either.
thanks, cheers
Replies (9)
ennujozlagam
it looks like your are downloading a server license and not a standalone license?txcs
hallalleon
Yes I am downloading a server license since they have the 2021 version
ennujozlagam
same process here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-s...
hallalleon
Thanks a lot, I will try this and see if it works
mdavis22569
if it doesn't can you share a screenshot of the error message?
Mike Davis
hallalleon
 this is the error i got
mdavis22569
Have you seen the following AKN article about this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Also make sure ALL of your updates from the Autodesk Desktop App are installed.  Revit and Autodesk
Mike Davis
hallalleon
thanks a lot @mdavis22569 it worked after updating this single sign on component
mdavis22569
Awesome ... glad I could help!
Mike
Mike Davis
