Hi guys
need to understand how can i correctly add content libraries like these :
This example are from an manual install of 2018, but our goal for revit 2020 is the have the same by using a command line.
The command line we are investigation now is like this :
"Revit_2020_G1_Win_64bit_dlm\setup.exe /t /w /qb /language en-us /c RCL: CP_PREFERENCE=RVT-en-US-i CP_SELECTED="RVT-en-US-i;RVT-en-US-m"
not sure if it's because we install the core revit software before the content libraries or if we didn't have the right command parameter or values....the folder aren't there in the libraries folder...as we didn't have libraries folder......we also look at the documentation but didn't find something specific to our situation.
Is there someone that can help on this..or indicate any other documentation that lead up to succeed...installing these 4 content libraries.
Normally in a manual installation...we would check these options :
The label in the screenshot are in french...but i assume you can situate you.
Thank in advance for all your help
