After installing the 2020.02.5 update from the Desktop App, The Revit version remains unchanged as 2020.02.4. I tried uninstalling and reinstalling the update but with no luck. It does not give me an error but it seems like the installation process takes just a second that is odd as the package is about 480MB.
Anyone had a similar issue or know how to resolve it?
TY.
Solved by atashpareh. Go to Solution.
Hello @atashpareh,
Thank you for sharing the steps you have taken and the observations you made. The fact that you mention a delay in the installation processing and applying the update. This makes me believe there is some interference within your environment, so try running through these steps.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thank you for your response but, unfortunately It did not solve my problem.
I also found out that my Autodesk Desktop Connector is not up to date and the update does not finish installing as well. It gives me a Fatal Error message in the middle of the installation.
I'm thinking of uninstalling and installing a fresh copy of Revit2020. I hope it solves the problem.
