Hello there,
I'm trying to install the new Revit 2018 but installation keeps failing. Could someone give me a hint about what i'm doing wrong?
I did a research on google and tried to uninstall all the Microsoft Visual C++ but didn't work. I'm curious cuz i installed Autocad 2018 without any problem. I tried to download AIDA but it just gave me a different error (attached).
That's it, i want to learn how to use revit and i would appreciate if someone could help me to install it.
Thank you VM,
Solved by renan.jose. Go to Solution.
I would start here and to resolve the AIDA error message clean out your personal temp (%temp%) folder.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks for the help, i did some research and made use of major geeks Visual C++ Runtime Installer (All-In-One) v54 ( http://www.majorgeeks.com/files/details/visual_c_runtime_installer.html), after that i did some modifications on the setup.ini file getting rid of all those prerequisites related to visual C and it worked pretty well. Thank you again.
