I've tried to install Revit 2018 several times through different methods but but it always fails because of unknown error. From the log files I can see that Microsoft Visual C++ files fail to install and after failed installation I've uninstalled all those files and tried again but it didn't help and I even rebooted my computer but that didn't help either. What I also don't get is that in the beginning of the installation process the Microsoft Visual C++ files are installed succesfully but then at the very end of the process it tries to install them again and fails. I'm using Windows 10 on my computer. How can I fix this?
Solved by mpeperkamp. Go to Solution.
Hi @Anonymous,
We need some more information, but if you haven't tried a Browser Download & prepared your system for a download & install, you can give it a try. Download the software via the Autodesk Virtual Agent or Autodesk account using the Browser Download from the drop down.
Use Browser Download Method from Autodesk Account or via the Autodesk Virtual Agent (download all the parts)
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
