Good day:
I need to install the 2024 versions of the 2022 apps below. I have only been able to locate some. I have not been able to locate the Autodesk installation packages they are contained in. See attachment.
Autodesk Revit 2024 Revit MEP Imperial Content
Autodesk Revit Content Essential-ENG 2024
Autodesk Advanced Material Library Base Resolution Image Library 2024
Autodesk Advanced Material Library Low Resolution Image Library 2024
Autodesk Revit 2024 Revit MEP Metric Content
Autodesk Material Library 2024
Autodesk Advanced Material Library Medium Resolution Image Library 2024
Autodesk Material Library Low Resolution Image Library 2024
Autodesk Material Library Medium Resolution Image Library 2024
Autodesk Material Library Base Resolution Image Library 2024
The material libraries are part of the Revit installation / deployment. Content packages can be downloaded separately.
The Material Libraries are no apps - they are just static content. And as I said before, they're included in the Revit installer.
As for MEP content - logon to your Autodesk Account, head to Products and Services > Revit 2024 > View Details > Libraries and select the stuff you need.
And while you're there, you also may want to check Updates and Extensions.
