Replacing old lic file and upgrading software
I have replaced my Lic file and upgraded the LMTOOLS I dont see any errors in the logs. I now am getting Network License Not Available when starting apps.
Replies (18)
Mark.Lancaster
@Anonymous
You need to give us more information like the error code that is issued.  Just stating its unable to obtain a license means many things.  Share the debug log file that is defined under the config service tab of your LMTOOLS.
Mark Lancaster
13:52:27 (lmgrd) -----------------------------------------------
13:52:27 (lmgrd) Please Note:
13:52:27 (lmgrd)
13:52:27 (lmgrd) This log is intended for debug purposes only.
13:52:27 (lmgrd) In order to capture accurate license
13:52:27 (lmgrd) usage data into an organized repository,
13:52:27 (lmgrd) please enable report logging. Use Flexera Software LLC's
13:52:27 (lmgrd) software license administration solution,
13:52:27 (lmgrd) FlexNet Manager, to readily gain visibility
13:52:27 (lmgrd) into license usage data and to create
13:52:27 (lmgrd) insightful reports on critical information like
13:52:27 (lmgrd) license availability and usage. FlexNet Manager
13:52:27 (lmgrd) can be fully automated to run these reports on
13:52:27 (lmgrd) schedule and can be used to track license
13:52:27 (lmgrd) servers and usage across a heterogeneous
13:52:27 (lmgrd) network of servers including Windows NT, Linux
13:52:27 (lmgrd) and UNIX. Contact Flexera Software LLC at
13:52:27 (lmgrd) www.flexerasoftware.com for more details on how to
13:52:27 (lmgrd) obtain an evaluation copy of FlexNet Manager
13:52:27 (lmgrd) for your enterprise.
13:52:27 (lmgrd)
13:52:27 (lmgrd)
13:52:27 (lmgrd)
13:52:27 (lmgrd) Server's System Date and Time: Fri Jun 16 2017 13:52:27 Eastern Daylight Time
13:52:27 (lmgrd) pid 8048
13:52:27 (lmgrd) SLOG: Summary LOG statistics is enabled.
13:52:27 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:52:27 (lmgrd) Done rereading
13:52:27 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on WDS2.lbps.boe (IBM PC) (6/16/2017)
13:52:27 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
13:52:27 (lmgrd) World Wide Web: http://www.flexerasoftware.com
13:52:27 (lmgrd) License file(s): E:\AutoDesk License\WDS2.lbps.boe002481e1f3a0.lic
13:52:27 (lmgrd) lmgrd tcp-port 27000
13:52:27 (lmgrd) (@lmgrd-SLOG@) ===============================================
13:52:27 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
13:52:27 (lmgrd) (@lmgrd-SLOG@) Start-Date: Fri Jun 16 2017 13:52:27 Eastern Daylight Time
13:52:27 (lmgrd) (@lmgrd-SLOG@) PID: 8048
13:52:27 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
13:52:27 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
13:52:27 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
13:52:27 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
13:52:27 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
13:52:27 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
13:52:27 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c E:\AutoDesk License\WDS2.lbps.boe002481e1f3a0.lic -l C:\Program Files\Autodesk Network License Manager\Logs\AutodeskNLM.log -z -s
13:52:27 (lmgrd) (@lmgrd-SLOG@) License file(s) used: E:\AutoDesk License\WDS2.lbps.boe002481e1f3a0.lic
13:52:27 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
13:52:27 (lmgrd) Starting vendor daemons ...
13:52:27 (lmgrd) Starting vendor daemon at port 2080
13:52:27 (lmgrd) Using vendor daemon port 2080 specified in license file
13:52:27 (lmgrd) Started adskflex (pid 8080)
13:52:27 (adskflex) Unable to initialize access to trusted storage: 1
13:52:27 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
13:52:27 (adskflex) SLOG: Summary LOG statistics is enabled.
13:52:27 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
13:52:28 (adskflex) SLOG: VM Status: 0
13:52:28 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
13:52:28 (adskflex) Server started on WDS2.lbps.boe for:
13:52:28 (adskflex) 85788BDSADV_F (consisting of: 86697BDSADV_2017_0F
13:52:28 (adskflex) 86443BDSADV_2016_0F 86245BDSADV_2015_0F 86073BDSADV_2014_0F)
13:52:28 (adskflex) EXTERNAL FILTERS are OFF
13:52:28 (lmgrd) adskflex using TCP-port 2080
13:52:28 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
13:52:28 (adskflex) SLOG: TS update poll interval is 600 seconds.
13:52:28 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
13:52:28 (adskflex) (@adskflex-SLOG@) ===============================================
13:52:28 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
13:52:28 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
13:52:28 (adskflex) (@adskflex-SLOG@) Start-Date: Fri Jun 16 2017 13:52:28 Eastern Daylight Time
13:52:28 (adskflex) (@adskflex-SLOG@) PID: 8080
13:52:28 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
13:52:28 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
13:52:28 (adskflex) (@adskflex-SLOG@) Options file used: None
13:52:28 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
13:52:28 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
13:52:28 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
13:52:28 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
13:52:28 (adskflex) (@adskflex-SLOG@) === Network Info ===
13:52:28 (adskflex) (@adskflex-SLOG@) Listening port: 2080
13:52:28 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
13:52:28 (adskflex) (@adskflex-SLOG@) === Host Info ===
13:52:28 (adskflex) (@adskflex-SLOG@) Host used in license file: WDS2.lbps.boe
13:52:28 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: None (Physical)
13:52:28 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
13:52:28 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
13:52:30 (lmgrd) Rereading license file... Requested from dmbooth@WDS2
13:52:30 (adskflex) TCP_NODELAY NOT enabled
13:52:30 (adskflex) Rereading license file...
13:52:30 (lmgrd) Done rereading
13:52:30 (lmgrd) ...Finished rereading
13:52:30 (adskflex) Server started on WDS2.lbps.boe for:
13:52:30 (adskflex) 85788BDSADV_F (consisting of: 86697BDSADV_2017_0F
13:52:30 (adskflex) 86443BDSADV_2016_0F 86245BDSADV_2015_0F 86073BDSADV_2014_0F)
13:52:30 (adskflex) Updating feature 85788BDSADV_F
13:52:30 (adskflex) Updating feature 86697BDSADV_2017_0F
13:52:30 (adskflex) Updating feature 86443BDSADV_2016_0F
13:52:30 (adskflex) Updating feature 86245BDSADV_2015_0F
13:52:30 (adskflex) Updating feature 86073BDSADV_2014_0F
13:52:30 (adskflex) Rereading options file...
13:52:30 (adskflex) (@adskflex-SLOG@) ===============================================
13:52:30 (adskflex) (@adskflex-SLOG@) === Reread Info ===
13:52:30 (adskflex) (@adskflex-SLOG@) Reread time: Fri Jun 16 2017 13:52:30 Eastern Daylight Time
13:52:30 (adskflex) (@adskflex-SLOG@) Number of rereads since vendor daemon startup: 1
13:52:30 (adskflex) (@adskflex-SLOG@) Reread mechanism: Manual
13:52:30 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
13:52:30 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
13:52:30 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
13:52:30 (adskflex) (@adskflex-SLOG@) Options file used: None
13:52:30 (adskflex) (@adskflex-SLOG@) License file(s) used: E:\AutoDesk License\WDS2.lbps.boe002481e1f3a0.lic
13:52:30 (adskflex) ...Finished rereading
Mark.Lancaster
@Anonymous
Error code the end user is seeing when they try to obtain a license?  You may have to cancel those message a few times in order to see the error code.
Mark Lancaster
Mark.Lancaster
@Anonymous
I would start >>here<< if not already.  Also make sure your firewall is not blocking ports or add the exception
Mark Lancaster
How can i verify the correct license? I am pretty sure the server is not being blocked as it was running the older version and lic file without issue this morning.
License file(s) on WDS2.lbps.boe: E:\AutoDesk License\WDS2.lbps.boe002481e1f3a0.lic:
WDS2.lbps.boe: license server UP (MASTER) v11.13.1
Vendor daemon status (on WDS2.lbps.boe):
adskflex: UP v11.13.1
Feature usage info:
Users of 85788BDSADV_F: (Total of 125 licenses issued; Total of 0 licenses in use)
Users of 86697BDSADV_2017_0F: (Total of 125 licenses issued; Total of 0 licenses in use)
Users of 86443BDSADV_2016_0F: (Total of 125 licenses issued; Total of 0 licenses in use)
Users of 86245BDSADV_2015_0F: (Total of 125 licenses issued; Total of 0 licenses in use)
Users of 86073BDSADV_2014_0F: (Total of 125 licenses issued; Total of 0 licenses in use)
is what i see
DarrenP
the feature code that is showing in that log is for Building Ultimate which does not come with Autocad Electrical
what other products are in this license file?
DarrenP
Mark.Lancaster
@DarrenP Nice catch..  I glazed over the splash screen and was only looking at the error code..  Smiley Very Happy
Mark Lancaster
hmm just seeing that now
Product:
Product Design Suite Ultimate 2017
License Type:
Education Network
Access Type:
Multi-user
Authorized Usage:
Installation on network server shareable by up to 3000 concurrent users
Product Key:
781I1
Serial Number:
561-********
i must be generating the wrong license file
but I don't see this as a option when I click generate file.
Mark.Lancaster
IF you are trying to do this through your Autodesk Account that may explain it..  Others have always had issues.
Here a 2 other ways you can do it..
To generate a license file (pick one)
1.  The contract manager or software coordinator for you subscription can log into their Autodesk Account and select Generate License file link
2.  Go to the Autodesk Register Once Web site and follow the prompts.  With Register Once you have to repeat the process for each network serial # that you have and then combine the license file at the end.
3.  Contact your reseller and they will do it for you.
4.  Contact Autodesk here and they will do it as well.
Mark Lancaster
we are a school so its free.
Mark.Lancaster
Yes its free but not sure why you replied that..  Smiley Very Happy
Mark Lancaster
hangs right there
I am a fool
Nevermind IE worked i got the file and all is well. Thank you for everyones support
natasha.l
Hello @Anonymous,
My suggestion since the registeronce.com is not working for you, is to create an Educational Account & select the proper Educational Role (IT Admin) this will allow you to generate a license file in the account within 24-48hrs after creating it.
Helpful Link: Manage Your Licenses & Software in a Network Environment
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
