Hi, I must replace my dying computer. How do I transfer the "seat" to the replacement computer as to retain both seats under licence? This is just in case I need to install the 2nd seat on an additional machine in the future. Thanks
@Anonymous
Welcome to the community..
You can use the License Transfer Utility (LTU) located under the Autodesk section of your Windows Start menu. However this interface is not reliable and you may end up having a problem. My advice just install the application on the new machine and then perform a clean uninstall (on existing machine) per these instructions. If the end you can't can straighten out the install on 2 devices down the road if needed.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Like @Mark.Lancaster said, the license transfer will fail if the contract is expired, and/or you're trying to transfer a older product version license... That being said, just install and activate on the new machine.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
