04:44 PM
- Mute
- Permalink
- Report
I'm trying to install Maya 2017. When I open it takes me to the "Let's Get Started". I choose enter serial number and it crashes. I entered a support ticket and my answer was:
- Go to Start > All Programs > Autodesk > Uninstall Tool
- Select Maya 2017 and click Uninstall.
- Remove the Trusted Storage files (Licensing) located in these areas:
- Windows Vista/7/8/10
- C:\ProgramData\FLEXnet\adskflex_########_tsf.data
- C:\ProgramData\FLEXnet\adskflex_########_tsf.data.backup
- Delete any residual Program Files from these locations:
- C:\Program Files\Autodesk\
- C:\Program Files\Common Files\Autodesk Shared
- C:\Program Files (x86)\Autodesk\
- C:\Program Files (x86)\Common Files\Autodesk Shared
- C:\ProgramData\Autodesk\
- C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
- C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
- C:\Users\All Users\Autodesk\
The program folders should be clearly named.
- Clean out your TEMP files:
- Click the Windows Start button.
- In the Run box type %TEMP% and press Enter
- Highlight and delete all files. Ignore any files in use.
- Reinstall Maya 2017 from the correspondent folder inside C:\Autodesk (if you need to re-download it you can get it from Virtual Agent)
- At the Let's Get Started window select Enter a Serial Number and type in your SN
But it still isn't working. Thanks in advance
