During downloading autocad student version I didnt get any serial number and product key which os asked to be entered while running autocad software
Solved by leowarren34. Go to Solution.
Hi @Anonymous
If you don't receive the serial number, you can see it on your Account Manager.
Go to manage.autodesk.com
Enter in 'All products and downloads' and search for the software:
Then click on 'View downloads' and search the activation tab.
im presenting the same issue due to do the problem that i have lack of options on my account management, I cannot see my serial number neither access to any other option
this documented on the student website
autodesk no longer provides serial numbers
its based solely on your Autodesk Account
for problems with your autodesk account
contact edu support: https://www.autodesk.com/education/support/edu-contact-us-form
Hi @Anonymous,
You now just log in with your Autodesk Account within the software to activate, on the 'Let's Get Started Screen' select Single User unless you see Sign In where you can then log in with your Autodesk ID and Password.
@JuanYusta Serial numbers have now been retired for educational accounts in all but a few special cases.
@Anonymous @Anonymous @leowarren34 @JuanYusta
Now I am able to use the software by just signingin with my autodesk account.
Thanks for helping.
