Whenever I try to activate my AutoCAD 2018 account, it shows a processing error every time. The error says that the system encountered a problem registering or activating your product.What should I do.Can someone help?
@Anonymous
Welcome to the Autodesk COmmunity.,
What type of license do you have? Student or commercial?
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
If you go into manage.autodesk.com and log in and under all products and services, do you see you application there?
Mark Lancaster
@Anonymous
Try activating offline https://knowledge.autodesk.com/customer-service/download-install/activate/manual-activation-registration
Mark Lancaster
Is it possible if you could make some changes to my account or help me manually activate it?Because I have had this issue for very long already and I need to use AutoCAD urgently for my school work. Or is it possible if you could provide me an activation code?I would greatly appreciate it
@Anonymous
I'm a user just like you. I have no access to your Autodesk Account or activation of your product.
Remember this is a user based forum and not Autodesk support.
In addition since you have an educational/student account, your Autodesk support must be done through and only through the Autodesk Educational support team: https://www.autodesk.com/education/support/edu-contact-us-form
Mark Lancaster
I already talked to an agent(about a week ago) and she said she would forward my case to the technical team but so far I have still not received an update
