Hi.
I am ACI and ACP from Poland. The Polish version of the application has had a problem with the block palette (Ctrl+3) for several versions. Block names (in tool properties on the palette) have a long dash instead of the short one in the source files. You can change the dash type manually on the palettes, but then you lose the appearance of the icons.
My question: how can I report this problem. I work under an NFR license, so using the help of an assistant is not possible.
