Installation & Licensing
174 Views, 2 Replies
Please activate!!
Hello.
I wanted to use an educational inventory and installed it. However, the request code is incorrect.
What should I do?
product Inventor professional 2019
License type Education Stand-alone
Access type single-user
Authorized usage Install on up to 2 personal devices
Prosuct key 797K1
Serial Number xxx-xxxxxxxx
Licensee Kim dalhee
requset code C1PN 513V V29T NUQX S3PA 9394 XZ7L 3APZ
Please activate!!
2 REPLIES 2
leowarren34
@Anonymous This is a user forum we don't activate products here, only autodesk does that.
Check http://manage.autodesk.com, there you should see Inventor Professional and under that 2019, which should have your serial number (The system managed to catch it and X it out- for future don't post your Serial number on the forum).
You should be able to log in to activate Inventor 2019.
If Inventor 2019 doesn't appear in manage: Request here: https://www.autodesk.com/education/free-software/inventor-professional
If that fails try Education support: https://www.autodesk.com/education/support
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
@Anonymous
Adding to @leowarren34 reply..
What do you mean the request code is incorrect?  The request code is generated by your computer that Autodesk uses to activate your student license.
Can you give us more details in why you can't activate?   Also just to confirm did you install Inventor or Inventor Professional?  Although the installer does both, you may didn't catch the option and installed (standard) Inventor and thus that's why it won't activate.
Mark Lancaster
Administrator Productivity
