PAF Error = 4 Line = 8191
Message 1 of 8
we needed to reinstall PowerMill on an new Operating System which gives us: PAF Error = 4 Line = 8191
Dongle ID: 49843 (DC2B3)
I can't find any useful links to reactivate/Regenerate the PAF File. Could you please sent us a working one?
Kind regards
Replies (7)
Message 2 of 8
Pijetro
Where does your PAF file reside?
Message 3 of 8
NanchenO
Hello, @Anonymous,
If you still have the old PAF file somewhere (e-mail or whatever), you can re-use it, because it is only linked to the dongle itself.
That means that you can use it on any PC, as long as the dongle is physically attached to the PC. It just should be located by default in c:\dcam, as long as I can remember (I have a network license, which is not working 100% the same way). Don't forget to install also the PAF wizard for a standalone dongle: This should help you to validate your license.
If you have no way to find your PAF file, then you should take contact with your Autodesk's representative, since I don't think that there is any way to retrieve it from the former Delcam forum.
Olivier
Message 4 of 8
Pijetro
Try and see if this article helps..
Message 5 of 8
Thank you very much. I managed to restore the paf from the broken disk 🙂
Message 6 of 8
Hi, I am also facing this issue please help me with this.
Message 7 of 8
2016 powermill delcam install all file then show paf file error 8191 ,so how to solve paf error
Message 8 of 8
Mark.Lancaster
@Anonymous
Welcome to the Autodesk community.
Where did you get this version (since its retired)?
Mark Lancaster
