Hello everyone, after installing AutoCAD2024/2025 on my computer, a pop-up window with a license error will automatically appear: Ask to contact customer support. After that, I also contacted customer service once: I found that as long as there is a pop-up window with a license error, I just need to reinstall AdskIdentityManager to use it normally! However, the licensing error problem will automatically occur again in the following period, and it is too troublesome to reinstall AdskIdentityManager every time in anticipation of the final solution to the problem. thank
Solved by Valentin-WSP. Go to Solution.
Take a look at the suggestion provided:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
