I am new to the AUTOACAD network license server.
I have a old server using ADLM which is currently running on 2 network license for autocad 2000.
Over the years the company had purchase other version of AUTOCAD network licenses but was fully utilize.
First Question is:
I would like to consolidate the different version of AUTOCAD network licenses into one network license server is it possible.
If yes how can I do it?
License purchased:
AUTOCAD 2000 x 2
AUTOCAD 2006 x 2
AUTOCAD 2007 x 7
Second Question is:
In total I have 11 AUTOCAD licenses, I do know that I can use only 7 machine with AUTOCAD 2007
but can I utilize the license and use 11 machine install with AUTOCAD 2000 version?
Can anyone advise on my situation.
Ken
Solved by JoAnn_Hogan. Go to Solution.
Hi Ken,
Welcome to the Autodesk Community,
First of all your products is out of date. Autodesk only supports the current version (2014) and 3 versions back (2013, 2012 & 2011)
There is a way to add the different version licenses on the same server. But this is something your VAR would be able to do and Autodesk self. Its not something you as the user can do. And because your products is out of date I doubt that they would be able to change that for you.
Ok Getting to your second question:
Let say you have 5 seats but you have 10 users. Only 5 people would be able to work at the same time,
Lets say you have 5 seats of one version and 5 seats of another version, all 10 users would be able to work but 5 on the one version and 5 on the other version.
