I need to perform a silent install of Maya 2020 with a Transform (MST) on the Maya installer. I already have the silent installation working with the silent deploy syntax. It works fine, but I need a transform tweak on the Maya.MSI file to be applied. How do we edit the XML files to have the silent install use the desired MST file?
Thanks!
Solved by m_latz. Go to Solution.
Hello @tracy_carlson,
The standard recommendation is provided on our Maya 2020 Help page. Although, I understand you are trying to apply transforms to the installer. I will reach out to @m_latz who maybe able to provide some suggestions for you.
Can you please provide an example of how you are applying it?
Please remember to "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
To pass parameter to an installation package just open the "pkg.*.xml" file in the same folder as the package and add the parameter "installParams" to the "InstallFile" entry.
An example:
I created a transformation for the maya.msi installation to not create the desktop shortcut. I copied my transformation to the same folder as the maya.msi file and added the following to the pkg.maya.xml file:
<InstallFile type="MSI" contents="Folder" installParams="TRANSFORMS=x64\Maya\MayaNoDtSc.mst" file="x64/Maya/Maya.msi"/>
That worked for me to apply my transformation. You can also pass any other properties to the msi.
regards
Markus
Thank you so much - I actually figured this out as well 2 days ago and was going to post my response.
@m_latz - Any clue how to get this working? I would like to log the MSI log file for Maya specifically to c:\windows\debug. When I put anything besides installParams="TRANSFORMS=x64\Maya\Maya.mst" it fails. I was thinking I could pass other MSI parameters within the installParams but it does not like it.
installParams="TRANSFORMS=x64\Maya\Maya.mst /lime c:\windows\debug\Maya_2020_20.0.0.235_Install.log"
If I modify <LogFile>Maya2020.log</LogFile> with a path in the pkg.maya.xml file, it does not like that either.
Thanks!
I tried only to apply the TRANSFORM, because if you can apply a transform, you can do anything.
Also enable logging and define the MsiLogFileLocation.
I try later to pass also other properties and will inform you.
regards
Markus
Okay tried and it is also possible to pass anything else to the msi.
if you call maya.msi via msiexec it is:
msiexec /I maya.msi TRANSFORMS="MayaNoDtSc.mst" ADSK_ADD_QUICKLAUNCH="0"
But because the new Autodesk installer uses a xml format you can not pass this, because in xml the begin and end of a string is marked with "
If you need " inside your string you have to mask them. So for XML it looks like:
installParams="TRANSFORMS="x64\Maya\MayaNoDtSc.mst" ADSK_ADD_QUICKLAUNCH="0""
where " is the mask for "
regards
Markus
And just another note,
I suppose the new Autodesk installer does not use "msiexec.exe" they use the internal windows api.
There /l does not work. You have to use MsiLogging and MsiLogFileLocation
Just try.
regards
Markus
