Does Navisworks Manage 2017 come free with enterprise BIM360 Glue license? I have been using Navisworks 2016 that comes with BIM360 Glue but when I downloaded 2017, I can only use trial after logging into my Autodesk account. Thanks for your help!
Solved by natasha.l. Go to Solution.
Hello @yangj_plantco_com,
Are you saying that you can only install the trial and it does not allow you to activate after the installation of the product?
Please try to install this Equipment Properties Add-in to fix the issue with BIM 360 if it does not show up it is integrated with Navisworks 2017 make sure to update with SP1 or SP2.
Keep us posted on the progress.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thank you for returning to the community with the feedback and Accepting As Solution to contribute to future visitors with a similar issue.
Keep posting!
Natasha
Helpful Links:
