multiple Chromium host executable in task manager
Message 1 of 11
Hi, every instance of max comes up as this on the task manager. It's problematic because when i need to force quit one max file when i have say 4 open I dont know which one is which because there is no file name anymore on the task manager.
I've tried everything here apart from disabling online help because I don't know how to in max https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Multiple-instances-of-ac...
I've uninstalled autodesk app and 360
I've unistalled every other autodesk app on my pc other than max.
This happened shortly after installing 2018
Anyone have a solution?
Many thanks in advance!
Replies (10)
Message 2 of 11
natasha.l
Hello @rwalker,
Before we try to resolve the issue, I would like to know what you are trying to accomplish. Are you not able to quit/close 3ds Max?
How to Remove Autodesk A360 on PC and Mac (& make sure to remove it from the taskbar)
Keep us posted.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 11
I can close and open max fine, but there are times when I have multiple instances of max open and if one freezes I need to force quit it via task manager.
However in my task manager every instance of max looks like my screen shot i sent, with no file name so I do not know which max I am force quitting when needed.
Before I installed 2018 it used to look like this in the task manager with the file name. see image below taken from a different pc without the issue
Message 4 of 11
Try a different Task Manager:
https://docs.microsoft.com/en-us/sysinternals/downloads/process-explorer
Usually once you force closed the program, all the Chromium host will not be attached to any program and you can force close them safely.
Almost all Autodesk program use Chromium host Process Explorer will show which program they attach to.
Message 5 of 11
Hi, thanks Frederik,
I guess this can be a work around for now if It works, (will test on monday in the office).
I'm just curious though why we have 14 computers in the office all with max 2018 but 2 of them display max in the task manager in this problematic way. All the other computers show it with the file name and no chromium processes attached to it. This was always how it had displayed for me through the last 5 years of using max until now.
Thanks again.
Message 6 of 11
In Task Manager, View Menu, try change the Group by type.
It could be new Windows 10 update.
Chromium host are not under Autodesk Desktop App on my computer.
Message 7 of 11
natasha.l
Hello @Anonymous,
In many cases the A360 app can be associated with this but it may be a 3rd party application that is blocking the access that Chromium needs to run during a program session.
Please try to review & conduct the following:
  • Disable the Welcome Screen options for each product. -- For example, in 3ds Max go to Help > Welcome Screen and in the lower left corner un-check the box to "Show this Welcome Screen at startup".
  • Add the acwebbrowser.exe *32 application to any Anti-Virus, Malware, Firewall or PC component tools/software as an exception (if applicable).
  • Log out of A360 Cloud Services (if and when possible).
  • Switch HELP to local files instead of online help files.
  • Change User Profiles to Admin (if and when possible).
  • Disable or manually start the Autodesk Desktop App. You can do this by going to:
    1. Windows Start > Run and type in "services.msc"
    2. Right-click on Autodesk Desktop App Service and select Properties.
    3. Under the General Tab choose a "Startup type" of your choice for this app (i.e. Disabled, Manual, etc.)
Message 8 of 11
hi natashal,
I've tried all that mentioned and it still persists. I have even uninstalled cloud 360 and the autodesk desktop app.
I tried using process explorer as frederik suggested but it still displays the same.
This is a shame because it makes the task manager useless when needing to force quit a specific max (if max freezes) file because I don't know which one I'm closing. It also means I don't know which max file is using up the most memory/cpu etc.
This is now happening to more computers in the office which makes me believe it is caused by max 2018 and the latest windows 10 update (build 16299) or just one of the two.
Do you have any other suggestions or know whether there will be a fix to this?
Message 9 of 11
natasha.l
Hello @rwalker,
Can you please rollback the update on one computer it may be due to Microsoft security updates you mentioned. Also, make sure to temporarily disable your Antivirus, how to here: Disable it in the Windows Defender Security Center app
Are all the computers updated to the latest windows 10 (build 16299)? Have you tried Event Viewer
Also, take a look at Task Manager, right-click "Properties" go to the "General" tab. This will let you know what is running the executable & we can find the root cause.
In this example the Autodesk Desktop App is running this executable:
Let us know how you are doing & if the suggestions help you find out the root cause.
Message 10 of 11
natasha.l
Hello @rwalker,
I wanted to check-in with you, I hope you were able to resolve this & have discovered the source of the issue.
Please report back & remember to “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 11 of 11
Would you be able to follow up on this issue? I have multiple instances of acwebbrowser.exe running.  Can I disable this?
Thank you.
Stew
