Mudbox 2024 activate problem.
tranhungUSF2T
tranhungUSF2T
Hello all,
I'm having problems with activate Mudbox 2024 in Windows.
After selecting enter serial number in Let's Get Start windows everything looks good but when click on activate button.  A Licensing Error window appears.
I try to uninstall and reinstall don't work.   I install on a new computer without any Autodesk software and still don't work.  Install with another admin account don't work.
My question are:
Is there a way to manually enter the the serial number into Mudbox?
Is there a way to activate Mudbox without using the Windows GUI?
Is there a way to inject/update a new serial number into Mudbox installation file?
Thanks.
Replies (13)
pendean
Community Legend
Community Legend
@tranhungUSF2T wrote:
...A Licensing Error window appears....
You will need to share a screenshot of that error: no one can guess at the challenge you faced without it.
tranhungUSF2T
Case #1
When click on activate button.
Case #2.
After re-download and re-install the software when click on Select (to enter serial number) Mudbox quit.
tranhungUSF2T
Ok I just upload 2 pictures.  Thanks for the reminder.
-Hung
DarrenP
read this: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Licensing-error-A-...
DarrenP
tranhungUSF2T
Done that but sadly Mudbox 2024 still not work.   I believed that Mudbox 2024 contain a new way of license activation for serial number.   I have no problem with Maya2024.   I also get the same problem when install Mudbox 2024 on a new computer.   Thanks for looking into it.
catstand9000
Mudbox won't work, just installed and it will not go pass the licensing options. The program will crash. I have Maya install and can confirm everything should be working, it's Mudbox that's not working.
tranhungUSF2T
Thanks for the confirmed that Mudbox 2024 won't work.    Here is the command that bring up the "Let's Get Started" windows if Mudbox 2024 crashed on start.
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change --pk 498P1 --pv 2024.0.0.F -lm ""
I'm still try to find the command for inject the serial number into Mudbox and also activate it with out click on activate button.   I hope somebody fix the activate button soon.
moore_college
Observer
Observer
I'm having this exact issue with mudbox 2024. Was a resolution found for the "A license error has occurred" error when trying to activate using a serial number?
oscar_diazHWKTM
Community Visitor
Community Visitor
Yo tengo exactamente el mismo error coloque un caso de soporte y solo me envían artículos que no resuelven nada saben si hay algun LOG que detalle mas el error?
oscar_diazHWKTM
Community Visitor
Community Visitor
Esto no funciona es lo mismo que me compartió a persona de soporte de autodeks
tranhungUSF2T
Sorry, no solution yet, but I have some ideas but will try to work on it next week or sooner.
tranhungUSF2T
On my system; error logs file location is in C:\ProgramData\Autodesk\AdskLicensingService\Logs.  Good luck.
Google translate
En mi sistema; La ubicación del archivo de registros de errores está en C:\ProgramData\Autodesk\AdskLicensingService\Logs. Buena suerte.
tranhungUSF2T
Just found this link about the license issue.   Don't have time to look at it.  Hopefully this will help with the activation license problem.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/A-license-error-ha...
