Installation & Licensing
450 Views, 4 Replies
menu
After installing a work menu in the autocad 9 we now dont have the standard dimensionng tool bar or the layer tool bar how do we get those back?
4 REPLIES 4
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
"9" or "2009", it's different ... 😉
And assuming 2009 where do you have that working menu from? And whoever created that menu, did he/she had a dimension toolbar?
When you start command _-TOOLBAR ==> Dimension ==> Show ... do you then see the toolbar?
If not you either have to ask the one who created that menu or you have to use CUI to add partial menus and so add the dimenion toolbar from a partial menu or you modify your "work" menu.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Thanks I'll check that out
Yes 2009
We were typing menu not toolbar I try it
[Description: Description: cid:image001.jpg@01CDEA65.17F5BEB0]
Brian LeCuyer, Purchasing Manager/Washington
Atrium Windows and Doors I 3400 Tacoma Street, Union Gap, WA 98903
phone: (509) 248-4462 Ext 114 I cell: (509) 833-5744 I fax: (509) 575-6776
brian.lecuyer@atrium.com I www.atrium.com
________________________________
This message is intended only for the use of the person(s) to whom it is addressed. It may contain information which is privileged and confidential within the meaning of applicable law. If you are not the intended recipient, please contact the sender as soon as possible. The views expressed in this communication may not necessarily be the views held by Atrium Windows and Doors, Inc.
Alfred.NESWADBA
Be careful, there are different commands and using the wrong one can completely make AutoCAD close to unusable.
If you use _MENU instead of _MENULOAD or _CUILOAD you close your "main menu" and replace it by your own one
The result can be that all the standard AutoCAD menus are gone.
Using _MENULOAD (or _CUILOAD) gives you the option to add additional menus to the default menu (instead of replacing the default menu) and that should be the prefered method to add some customized ribbons, toolbars, ...
- alfred -
Alfred NESWADBA
@Anonymous  Although Alfred.NESWADBA is assisting you.  In the future and for better results.   Please post this type of question over in the AutoCAD discussion group.   There's a section for each AutoCAd version.   This forum is stricly for installation/licensing issues and not direct application problems.
Mark Lancaster
Administrator Productivity
