Installation & Licensing
Maya LT will NOT install!
2 REPLIES 2
614 Views, 2 Replies
I've tried over a dozen time to install a free trial of Maya LT 2016. But every time it craps out and says it failed install. I've checked the installation log and I saw error codes 1603 and 1619. If any one knows how to fix this please tell me.
Tags (1)
2 REPLIES 2
Otto
Hello beachyshawn and welcome to the Autodesk community!
It looks like you are seeing Error 1619 while trying to install a program. The following article(s) should help you resolve the problem:
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Autodesk program installation fails
BIM 360 Add-in install error: "A newer version of this software is already installed"
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
Use the Virtual Agent to download the software:
If this information was helpful, please consider using the Accept Solution
Administrator Productivity
