Installation & Licensing
Maya 2025 linux (Rocky 8.6-8.9) Wayland license workaround?
0 REPLIES 0
Message 1 of 1
admin2JNL7
291 Views, 0 Replies
Same with MotionBuilder and MudBox also, when launching the app it runs the login splash screen, then crashes, or opens a webpage logs in and crashes.
This is down to the new license system/components. IDSDK failed to resolve some internal error
Have installed libraries listed here
https://help.autodesk.com/view/MAYAUL/2025/ENU/?guid=GUID-D2B5433C-E0D2-421B-9BD8-24FED217FD7F
and here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Additional-require...
Finally, switching the wayland session noted here, to classic X11 fixes this issue.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/3t2VQSfCGLLvGEwb2lPn44.html
If I switch back to standard Wayland it continues to work,  but if I change user it needs to be run again.
Is there a way to pass this information over to many users/machines rather than doing it manually?
Ant
0 REPLIES 0
Administrator Productivity
