Max seems to be calling up .Net framework 4.0.30319, but throwing an error.
I've tried running it as admin, tried running the "switch graphics mode" and everything. Nada.
Here's the Even viewer details:
Application: 3dsmax.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at <Module>.wWinMainCRTStartup()
__________________________
Max goes through the splash screen, and that's it.
So I guess color me unimpressed.....as usual.
Hello @Anonymous, @Anonymous @Anonymous
Product crashes can be due to several issues. I have listed some of the common issues associated with it. I will update you on the system requirements for 2018 as they are not listed yet.
Keep us posted.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
I've already decided you are correct. I will wait for #3. That's usually about the time when most of us would consider the software out of the initial "beta" release we get every year.
Just to be clear, I'm calling every release beta until the usual June-ish service pack fixing all of the issues that should have never been in the software in an official release. There are a lot of people who don't speak english as there primary language and I wanted to be inclusive and make sure everyone understood the (sad) joke.
I would like to take some time to illustrate why you should NOT provide customer service from a can. Half of these responses don't apply.
So thank for for #7. That was the one thing that actually made sense. I mean, it didn't Help anything. But it made sense to suggest it.
It is interesting.
I have broken c++ 2017 redistributable.
I tried to reinstall, and as soon as I installed c++ 2017 itself redistributable, I restarted the 3D max before rebooting and it started!
And after a simple reboot, already the same error again ...
Why???
That is, the problem is most likely in these redistributable.
I gave you a tip, and I'll try to reinstall my redistributable, and if I can fix it, I'll write exactly how I fixed it.
In any case, thanks that you are, autodesk.
@Anonymous.engelkemier
Uninstalling Arnold (MaxToA) from control panel fixed it for me. I don't use Arnold, but you could try the Arnold update from SolidAngle which is newer than the one that shipped with Max 2018.
So in my case a developer contacted me and said Vorbis was causing a problem. He said to update it. I Think FL Studio 12 installed that? I'm not messing with that.
I have no need for audio in Max, so I just moved the plugin from the folder.
In my case: remove C:\Program Files\Autodesk\3ds Max 2018\stdplugs\ProSound.dlc
It Might be worth just grabbing a bunch of the files in the stdplugs folder and move them. See if Max starts up. Just start adding half back in at a time until you narrow down what the cause of the crash is. Just a thought.
The answer is almost never on the list of things you get from support. The only times I have ever been helped by anyone at Autodesk the actual developer contacted me. Now if someone could just change the system to plain text and let me read the reports myself I wouldn't even have to contact them!
Good luck to you other crashers. Hopefully this helps you, it was the correct solution for me.
Hello @Anonymous,
Thank you for contributing to the community by providing the issue you encountered in your environment and how you were able to resolve it.
Natasha
Helpful Links:
Thank you for posting this. I was having the exact same issue, and had tried everything else that had been recommended. I also have FL Studio 12 installed, and removing ProSound.dlc worked for me as well.
I also confirm that the error has disappeared.
Now I would like to know how to return the sound.
After all, someone needs it. Can eat a template solution, for example another working plug-in.
Or Will it be enough to wait for the update, and return the file ProSound.dlc to the folder stdplugs? (Or will there be a new file?)
This error is registered, and will be fixed?
I have problems with one of the computers. 3DsMAX starts to load, but after an second loading stops with no error messages, no nothing. I have clean install with StingRay and 3ds Max Interactive.
Faulting application name: 3dsmax.exe, version: 20.0.0.966, time stamp: 0x58b4e2e6
Faulting module name: ExchangeStorePackageManager.dll, version: 20.0.0.966, time stamp: 0x58b4e077
Exception code: 0xc0000005
Fault offset: 0x0000000000001e78
Faulting process ID: 0x28d4
Faulting application start time: 0x01d2f4c5044ccf32
Faulting application path: C:\Program Files\Autodesk\3ds Max 2018\3dsmax.exe
Faulting module path: C:\Program Files\Autodesk\3ds Max 2018\ExchangeStorePackageManager.dll
Report ID: 2f8ec99a-fd43-4203-9a25-fa5a1565cb22
Faulting package full name:
Faulting package-relative application ID:
