Installation & Licensing
Links are dead in the Application Manager
5 REPLIES 5
ptranbergNTI
1833 Views, 5 Replies
Great new stuff in the Application Manager, only downside is that all the links for learning, help and videos are dead.
I Use Google Chrome (Have tryed IE as well) every link meets this message in Google Chrom and IE
"xoauth_problem=token_rejected&oauth_error_message=Token%20Is%20Rejected
Regards
PT
Regards
Peter Tranberg
NTI A/S, Denmark
revitogbim.blogspot.com
5 REPLIES 5
Otto
in reply to: ptranbergNTI
Hello pt
It looks like you're experiencing issues with the Application Manager. The following article(s) should help you resolve the problem:
Autodesk Forum Thread: Autodesk Application Manager
Autodesk Application Manager FAQ
How to Silently Uninstall Application Manager using SCCM
Error: Unable to run Application Manager
Autodesk Application Manager Error: SSL Handshake failed
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
ptranbergNTI
in reply to: Otto
The certificate is OK due to run out in 2023
All other articles refer to older versions of Application Manager
PT
Regards
Peter Tranberg
NTI A/S, Denmark
pendean
AAM is replaced with the Autoesk Desktop Application starting with 2017s releases.
make sure your AAM is the most current https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Where-to-download-the-Au... but after that it may not work because it's been replaced.
Good luck.
ptranbergNTI
in reply to: pendean
Sorry, I did not notice the renaming of the Application Manager.
This issue is about the Autodesk Desktop App. Version: 6.0.108.150
All Links to videos, learning and Help are dead
PT
Regards
Peter Tranberg
NTI A/S, Denmark
ptranbergNTI
Today the links work... Smiley Very Happy
Regards
Peter Tranberg
NTI A/S, Denmark
Administrator Productivity
