Installation & Licensing
Licensing of my AutoCAD 2015 for educational institution
3 REPLIES 3
529 Views, 3 Replies
I am a System admin of an educational institution, i have download free auto cad 2015 and activated for 3 years. I need to install the same serial key for another 50 computers for students use. I ghosted the disk to disk option. but it shows your license is invalid contact autodesk dealer. PLease give me the solution to solve this issue.
3 REPLIES 3
TheCADnoob
you'll probably get a better response in the license and install forum :https://forums.autodesk.com/t5/installation-licensing/bd-p/24
CADnoob
pendean
why did you go grab an old version of the program?
Darin.Green
That is correct, you'll need to uninstall the applications on every machine that you installed it on and reinstall.
This is the reason Network Licensing is better for education, because if something goes wrong you only have a single machine to troubleshoot (licensing server). I recommend going back to the education community and generate a serial number for network licensing. Rebuild your image or convert the software to network using this method (this can only be done on the master image). It will not work for the machines you imaged already because their licensing module is corrupted.
The reason you're having this issue in the first place is because you opened the software and activated it on the master image before building the deployment image.
When requesting the license information, choose School: Deploy with Network Server
If this information was helpful, please consider using the Accept Solution
Administrator Productivity
