License Transfer Utility Script Errors
lim_gm1985
lim_gm1985
I have the AutoCAD LT 2014 software single license which i would like to use between a win7 desktop and a win10 laptop. I tried to use the License Transfer Utility LTU to export/import the license but encountered the script errors when i try to sign in from the LTU window. Unable to proceed further. Attached screenshot of the errors.
Appreciate if there is any advice to resolve this issue ? Thanks.
leowarren34
Hi @lim_gm1985,
The main issue you are going to face is that AutoCAD 2014 is not compatible on Windows 10 which will likely be the cause of many errors.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
pendean
Community Legend
Community Legend
Your AutoCAD/LT2014 is not supported in Win10, which means Autodesk is not interested ever in helping you with any issue, it does not mean anything else you might read into "supported" http://autode.sk/1IY4C2X
Windows 10's updates also seem to break older AutoCAD licenses for some folks that require reauthorizing to get back up and running. BUT...
Autodesk will end automatic reauthorizing of 2016 and older software as of March 2021 (next month), read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
So... Do you have a backup plan so you are never dead in the water if/when that happens? I seriously hope so.
Good luck.
lim_gm1985
To add on, the LTU script errors (with screenshot posted) is on the win7 desktop. Wanted to use the LTU to export the license out. Is there any alternative to export the license without the LTU ?
lim_gm1985
Thanks for the reply. However, the License Transfer Utility LTU script errors i encountered (with the screenshot posted) is on the win7 desktop. Is there a way to resolve this so that i can export out the AutoCAD LT 2014 license ? Or otherwise, is there an alternative method to export the license for use without using the LTU ?
lim_gm1985
Thanks for the reply. Added some clarifications. The License Transfer Utility errors encountered was on the win7 desktop. Any way to resolve this so that i can export out the license ? Is there an alternative to export the license without the LTU ?
