Installation & Licensing
343 Views, 3 Replies
LICENSE FILE
MY WORK INSTALLED A NEW SERVER OVER THE WEEKEND AND NOW MY AUTOCAD SAYS IT CANT FIND THE LICENSE. I DID THE BROWSE AND DIRECTED IT TO THE LICENSE FILE (AT LEAST WHAT SAYS ITS THE LICENSE FILE) BUT IT STILL WONT RUN. CAN SOMEONE TELL ME WHAT I NEED TO DO TO GET THIS TO WORK? THANKS!
3 REPLIES 3
jggerth
and did you get new license codes from Adesk for the network license on the new server?    the old ones will not work -- the auth codes are tied to the old hardware,
camilo.lemos
Hi Tony,
as JGerth mentioned above we will need to generate a new license file for your network deployment. If you can PM me your products' serial number, your e-mail address, the name and Mac address of your new server I'll generate the license file for you and send it via e-mail.
Thanks!
Camilo Lemos
INACTIVE_Timmy.DeAustria
When you get your new License File, you have to do the following: On the Server: Make sure that Lmtools can read your new License File. On the Firewall settings, add exclusions to TCP port 2080 and 27000-27009. On the Workstations: Update the LICPATH.LIC file using Notepad (located on program directory) to reflect the new Server Name, if the Server Name changed. If you are using Environment Variable, update the Server Name, if the Server Name changed. It wouldn't hurt to delete CASCADEINFO.CAS file. CASCADEINFO.CAS can be located here: Windows XP: C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm Windows Vista and Windows 7: C:\ProgramData\Autodesk\Adlm Mac: /Library/Application Support/Autodesk/Adlm/.config Linux: /var/opt/Autodesk/Adlm/.config Please let me know if you need further assistance.
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. 😉
Administrator Productivity
