License error Autocad LT 2020
When we open Autocad LT 2020 and then open a dwg file everything is going fine.
When we don't open Autocad, but open a dwg file directly by double click on the file we get a license check time out.
This is the error we get:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-License-checkout-t...
But non of the solutions work and as I said before it's only when we open the dwg file without opening Autocad first.
Someone any idea?
Jessica
Replies (22)
leowarren34
What is the windows default program when opening .dwg files?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Is this WIndows service is there and running?
Mark Lancaster
The default program is Autocad LT 2020.
We've tried selecting another program and chance it back to Autocad LT 2020 but no difference.
Yes, the service is running.
When we open Autocad LT 2020 first and than open a dwg file there's no problem and licenses are found.
It's only on double tick on a file, without open Autocad first.
Mark.Lancaster
@Anonymous
What is that service startup set to?  Automatic, delay, etc?
Also is this service started?
If you stop both of them, can you start them again?
Mark Lancaster
@Mark.Lancaster
It's set to automatic.
And it's not a network license, so as far as I thought netflex isn't necessary?
Mark.Lancaster
@Anonymous
Yes that service is still needed for standalone license.  Prior to 2020, that was major service needed to run and activate your product.  So is it running or not?
Mark Lancaster
@Mark.Lancaster
Yes, it's running and started automatically
I have the same problem for Autodesk 2020 products with other details.
When we open Autodesk Products (Autocad, Revit, ...), I have to activate license by click on "Multi-user" :
then I can use and open a Autodesk file. I don't need to specifiy license or port server, I have already saved the information on ADSKFLEX_LICENSE_FILE variable environment.
But at first (like the first connection on the computer), if I open the Autodesk file by double-click, that doesn't work.
There is this step that I need to activate Autodesk Products. Without, It's not ok.
Is it possible to cancel this step and automatically connect to license Server ?
I verify Autodesk services, it's fine for me.
Best Regards
Molyce
P.S : Sorry for my english.
We've solved the problem this morning.
All file association in Windows where set to the right programm.
But, we are using RES Workspace/Ivanti and it's necesarry to add dwg as filetype to the Autocad application.
@Anonymous are you using a similar programm like RES/Ivanti?
Hi Jack,
I'm only an IT aministrator in a high school and I don't know if others software that i have installed can open .dwg file. But we don't use RES Workspace/Ivanti.
In my Windows 10, .dwg file is opened by default with Autocad Application :
Best regards
As a test... do you have the option of setting it to AutoCAD DWG Launcher? Does it help?
Sorry, that didn't work for me. Software always ask me to activate with this windows :
Best regards,
You mentioned this is a multi-user license, does this issue occur on just one PC or multiple computers?
All computers that i can install by imaging in my high school.
leowarren34
What imaging software are you using?
Leo Warren
Fog project
leowarren34
Have you seen this: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Deploying-Autodesk-Softw...
Leo Warren
Yes, I do. I am in the first case "For NLM installations". I have uninstall all products then reinstall them following steps for the 2 situations : that didn't work.
Now, I am going to activate products after imaging for each computers. It will be the only solution to deploy computers fastly.
But I am always looking for a solution for next deployment. If you have an idea, thanks for your response.
Thanks again for your help.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
