Installation & Licensing
Language Library will not install
2 REPLIES 2
293 Views, 2 Replies
I have tried several times to install AutoCAD Lt 2020 on a Win 10 computer.  Doing both from the deployment I have installed from before or directly from AD through the Desktop App/Subscription Service the installation fails towards the end saying it could not install language service and an error #1603.
I have found a post saying to install new Licensing installer 9.2.2.250, which I downloaded.  First, when I launch the file it asks for permission to install (usual) and then ..... NOTHING!  No evidence of it installing.
Well, maybe its a silent installer, but trying to install AC Lt again ends up with the same failure/error message.
What now?
Thanks in advance
I do not know if I can navigate back here to look for an answer, so my eMail is Leandro.Llambi@vla.net.  Please send me a link at least if you have posted a solution or have any questions.
Thanks in advance,
Lee
2 REPLIES 2
leowarren34
Have a look here first: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...
Please don't put your email online as it can be a security risk.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Mark.Lancaster
@Anonymous
Without your installation log file we can only speculate what the issue is at this point.  So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
Administrator Productivity
