Hi all I am running Autocad LT 2025 on Windows 10, I seem to be having this problem when I hit the CUI in quick properties I will get a pop up saying,
"Unhandled exception has occured in a component in your application. if you click continue, the application will ignore this error and attempt to continue.
Could not load file or assembly "System. Text.Encoding.CodePages,Version=8.0.0.0, Culture=neutral, publickey Token=b03f5f7f11d50a3a". The system cannot fine the file specified.
If I hit continue, it does take me to the Customize user interface, I can make changes , then hit apply, hit ok to close and the the same message pops up again, hit continue to close and the changes made seem to stick.
Its just a pain to keep getting this message, anyone have any ideas to fix this?
This happens on a new sheet, the file has no bearing on it happening or not.
