Keep getting message Unhandled exception has occured in a component in your application.
S.W.Eng
Message 1 of 11
S.W.Eng
Hi all I  am running Autocad LT 2025 on  Windows 10, I seem to be having this problem when I hit the CUI in quick properties I will get a pop up saying,
"Unhandled exception has occured in a component in your application.  if you click continue, the application will ignore this error and attempt to continue.
Could not load file or assembly "System. Text.Encoding.CodePages,Version=8.0.0.0, Culture=neutral, publickey Token=b03f5f7f11d50a3a". The system cannot fine the file specified.
If I hit continue, it does take me to the Customize user interface, I can make changes , then hit apply, hit ok to close and the the same message pops up again, hit continue to close and the changes made seem to stick.
Its just a pain to keep getting this message, anyone have any ideas to fix this?
This happens on a new sheet, the file has no bearing on it happening or not.
Replies (10)
Message 2 of 11
S.W.Eng
Here is a screenshot of the error.
Message 3 of 11
pendean
Community Legend
Community Legend
@S.W.Eng Is this a problem that just appeared today?
Or is this a new LT2025 installation?
Or...?
I will assume you've done that very basic restart-of-PC solution already: an LT2025 reset may be in order at some point too
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
Message 4 of 11
paullimapa
have you installed LT 2025.1.1 update?
Paul Li
IT Specialist
@The Office
Message 5 of 11
S.W.Eng
I don't know when it started but I noticed the issue about 2 weeks ago, just never looked into it until the day I posted this since i couldn't find any info on it. I have done a computer restart and a reset settings to default ,
Message 6 of 11
S.W.Eng
I have not, I didnt know there was a new update, will try it now.
Message 7 of 11
S.W.Eng
updating fixed my problem, Thank you.
Message 8 of 11
paullimapa
Glad that worked out for you…cheers!!!
Paul Li
IT Specialist
@The Office
Message 9 of 11
petervoegeli
I have this problem with Mechanical 2025 sp0 - sp1.2.
2025-04-09 16:12:34.5465 ERROR Fatal Autocad Errror System.IO.FileLoadException: Could not load file or assembly 'System.Text.Encoding.CodePages, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'. Could not find or load a specific file. (0x80131621)
File name: 'System.Text.Encoding.CodePages, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
---> System.IO.FileLoadException: Could not load file or assembly 'System.Text.Encoding.CodePages, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'.
A reset did not help
It was working, but stopped now.
Regards
Message 10 of 11
paullimapa
Have you tried resetting?
How to reset AutoCAD to defaults
May get better feedback by posting over here:
https://forums.autodesk.com/t5/autocad-mechanical-forum/bd-p/39
Paul Li
IT Specialist
@The Office
Message 11 of 11
petervoegeli
Resetting and/or installing SP 1.1 or SP 1.2 did not help.
I needed to downgrade to version 8 of the *.dll, now it is working.
Strange that it was working correctly....
Regrads Peter
