Hi all
I had 3ds Max 2016 installed on my machine running windows 10 and it was working fine, but I came back after the weekend and now it wont start. It loads the splash screen up to the point that it says its 'Starting 3ds Max...' and then.... nothing. When I open task manager it says its still running as a background program. When I ran it using the windows compatibility test I got this message;
Ive uninstalled all autodesk software from my machine and reinstalled from scratch and restarted a number of times today but to no avail. I need you 3ds Max forum, your my only hope!!
Cheers
Simon
P.S.
Having seen some of the solutions posted for earlier versions of Max;
-Ive tried running the .exe as Admin but got the same result
-There doesnt seem to be a HSDS.dlm in the AppData/Autodesk... directory
https://www.youtube.com/watch?v=UnPURNuDVNQ
(in short: locate 3dsmax.ini, should be in \Users\Username\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU,
find EnableCoreInterfaceProxySystem=1 and change it to
EnableCoreInterfaceProxySystem=0 )
