inventor2019: Installation incomplete. Some products failed to install
Inventor was installation failed, but my files are complete.I follow the steps in the web link to remove and reinstall Microsoft Visual C++ Runtime Libraries(https://knowledge.autodesk.com/zh-hans/search-result/caas/sfdcarticles/sfdcarticles/CHS/How-to-remov... the end, it failed. If someone could solve this,I will be very grateful!
mdavis22569
Try reinstalling the C++ / .NET and then run the installer again:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinst...
Mike Davis
Hi, I tried your method,but still failed to install. I reset the window10 and inventor was installed successful.
Anyway, thank you for your help.
best regards
mdavis22569
Sorry it took a Windows reinstall. I have seen this due to all of the recent updates for Windows that there are C++/.NET / Windows profiles and permission issues more so than prior to all of the W10 updates
Mike Davis
