Installation & Licensing
Inventor 2018 failed to install
25 REPLIES 25
Message 1 of 26
2379 Views, 25 Replies
Good day,
I am battling with the 2018 Autdesk Inventor installation. I followed a previous post suggesting to not download from the web application, which I did. The download manager finally downloaded, and I successfully downloaded the 12.5GB file. Once it completed I was not at the PC, however it required a restart, which I did (I thought it had successfully installed) After the restart, nothing happened and I cant find Autocad.
I looked for C:Autodesk which has the 12.5GB file "Inventor_2018_English_Win_64bit_dlm"  - If I run the setup, it brings up the download manager which has an option to "Install" - this opens an inventor screen which says "initialising" and then it comes up with an error " A software problem has caused Autodesk installer to close unexpectedly"
I have tried sending this error and have sent webforms, but no responce.
Can anyone assist me? I am not sure how to link install logs if that is needed?
Regards
Matt
25 REPLIES 25
Message 21 of 26
in reply to: mdavis22569
Hi Michael,
This is my PC, and I had not seen the article so thanks for the link.  I had previously wondered if the error was hardware related, but was doubtful that it would fail before, or on installation, as installation has no resource requirements relatively speaking. However the article does describe failure at this point due to hardware/software update issues. I had updated my PC prior to running these installs, however 4 updates failed, so I will attempt to rectify this and see if that helps.
Many thanks for all the assistance thus far to you, and palo and others.
I'll revert back.
Regards
Matt
Message 22 of 26
I managed to find a workaround for the failed update, and after those worked, I had a whole bunch of new updates to install. However the software still fails. My graphics card is a GTX 1050 2GB - fully updated, however I see I have an 8GB RAM stick that has failed so only running 4GB at the moment. would this lack of memory cause the pre-install to  fail?
Message 23 of 26
mdavis22569
For this:
No ... this should stop it.
However if you're having PC issues ... can you give the rest of the specs for the PC?
I know the video card is the GTX1050 ( not certified but will work)
Mike Davis
Message 24 of 26
Intel Core i5-2320 3.00GHz
At the moment 4GB RAM -getting another 8GB Friday)
Windows 7 -64bit home premium SP1 (updated)
500GB HDD -78gb free
nvidia GTX 1050 2GB
Motherboard Pegatron H61
Message 25 of 26
Hello all,
I found the solution to my issue. It was not compatible with Windows 7 Pro 64-bit for some reason. I installed Windows 10 and the install was successful thereafter. Support had assisted me and tried to run a few fixes with Windows 7, but it was not successful. So they recommended upgrading to Win 10, and sorted.
Many thanks to the people who took the time to reply and assisted.
Message 26 of 26
mdavis22569
@Anonymous
Windows 7 is approved for IV2018:
System Requirements for Autodesk Inventor 2018
Operating System ¹
  • 64-bit Microsoft® Windows® 10
  • 64-bit Microsoft Windows 8.1 with Update KB2919355
  • 64-bit Microsoft Windows 7 SP1
Could have been an OS issue blocking it / profile / conflict .... I still help people weekly on W7 ..
Mike Davis
Administrator Productivity
