I have a Mac mini that was running AutoCAD LT just fine until a few days ago. When I became aware of the problem, I would click the icon in the dock and, it would just bounce for a bit, and never start. It didn't freeze. It just never started. My user did download an AutoCAD LT update a few days ago, but thinks it worked OK after that. The OS is 10.11.
And one other thing: Despite having gone through the installation process, there is no Autodesk folder or AutoCAD app in the Applications folder. I've tried re-downloading the installer and even chatted with Autodesk to no avail. Can someone please help me?
Solved by tech. Go to Solution.
After uninstalling the software, make sure you delete the Autodesk directory in Library/Application Support
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
After speaking with someone from Autodesk, this problem was resolved by reinstalling the operating system. This allowed us to then reinstall AutoCAD and everything worked as it should. Thanks for the help. Hope this helps.
