Installation error Autocad 2019
Good evening,
I'm having a problem installing Autocad 2019 (student activation). Already use fusion 360, and i didnt had a problem with that.
Here it is
Already clean the temp folder, install as administrator, but no luck
I also added 3 log files that are created on install, that may help you figure out a solution
Hope you guys can help me.
Best regards
Darin.Green
@Anonymous
The issue is caused by using the Install Now/Web Installer option which in most cases fail due to installing and downloading at the same time. Please downloading the full application from here: AutoCAD 2019
That should work for you. Let me know if you have any questions.
If this information was helpful, please consider using the Accept Solution
Mark.Lancaster
@Anonymous
Not sure if the info @Darin.Green provided resolved the issue but...
Review this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal... and that doesn't resolve the issue create a new WIndows users account on your machine with admin rights and install using that new account.
Mark Lancaster
@Darin.Green and @Mark.Lancaster first of all thanks for the help. I downloaded from the link and tried to install. After the extraction it gave me an error similar to what @Mark.Lancaster said. So i changed the temp files as the tutorial said but now after the extraction it doesn't do anything. tried the setup.exe from the AutoCAD_2019_English_Win_64bit_dlm extrated folder and nothing, tried AutoCAD_2019_English_Win_64bit_dlm\x64\en-us\setup.exe and nothing... Hope this kind of stuff only happens to a few people, becouse software like this shoul not give this kind of headache
EDIT. tried in another account with admin permitions (remember that my current account also have this permitions) and it installed and worked
Do you guys know what causes this kinds of problems, Wondows, or autocad?
Thanks again for the help
Mark.Lancaster
@Anonymous
This issue has been around for "X" number of issues and earlier solutions was to create a new Window account because there was something wrong with the account itself.   Or something changed in your account over time and caused this issue.  But there's never been a root cause defined outside of the temp folder mapping.   Lately the temp folder remapping has resolved this issue but some are still faced with the issue and the other solution is to create a new Windows account.
Mark Lancaster
