Installation & Licensing
Installation complete. Some products failed to install
4 REPLIES 4
1006 Views, 4 Replies
Hello Autodesk Community,
I am trying to install Autocad Map 3D 2017 student version on my laptop and I still have some trouble to install it. I tried it in different ways but every time I get the same message. I am using Windows 10.
Please help me to solve this problem. Thanks!
Edited by request
Discussion_Admin
4 REPLIES 4
Otto
Hello cmoragui and welcome to the Autodesk community!
It looks like you're seeing the "Some Products Failed to Install" error. This error can be caused if prerequisites have already been installed on the target machine. Incompatible versions, or even the same version, can cause this problem. The following article(s) should help you resolve the problem:
Error: "Install complete. Some Products Failed to Install"
After uninstalling the necessary files, please fully shut down your computer and reboot it for the changes to take effect.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
cmoragui
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post, attach screen shots, or share any personal information (such as your serial #) here.
Your download is failing due to the method you're using (most likely its the Install Now option).   Review the verbiage below the line/above my signature and follow those steps to download and install your application.
Mark Lancaster
in reply to: Otto
Hello Otto,
I just finished installing Autocad Map 3D 2017 on Windows 10-64bit, and it works perfect! Thanks for your help!
in reply to: Mark.Lancaster
Many thanks Mark, I followed your steps for installation and it works!
Administrator Productivity
