Install failed - Pipe is being closed
Message 1 of 15
I've got a few users that for some odd reason, when they attempt to download/install the Inventor 2019.4 update, they are getting the "Install Failed - Pipe is being closed" error.
Why?
Replies (14)
Message 2 of 15
Mark.Lancaster
@Anonymous
Where are they doing this from?  Desktop App?
Mark Lancaster
Message 3 of 15
@Mark.Lancaster, No, the exe file is on a shared network drive.
Message 4 of 15
Mark.Lancaster
@Anonymous
Sounds like a network issue at your end if you downloaded the update..
Copy the update locally and see if the issue is still there.
Mark Lancaster
Message 5 of 15
@Mark.Lancaster,
I've got the user attempting this as we speak.
I'll let you know.
Message 6 of 15
Nope, same deal.
Message 7 of 15
Can you post a copy of the log file it refers to?
Message 8 of 15
@Anonymous, @Mark.Lancaster , See attached.
Message 9 of 15
Mark.Lancaster
@Anonymous
In researching this error it appears to be related to a registry issue or a missing entry in the registry.
You may want to run a registry cleaner (at your own risk).
Were there any other dot releases applied to Inventor?
Mark Lancaster
Message 10 of 15
@Mark.Lancaster, he's at 2019.1 currently.
Message 11 of 15
What language is your Inventor set to? Looking at the install log it seems to be hiccupping on this particular language pack...
Product or related product not found: {7F4DD591-2364-0001-1029-7107D70F3DB4}
I wonder if downloading the English language pack would help?
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/downloads/content/inve...
Just a wild guess though as I haven't seen this error before...
Message 12 of 15
It's set to English.
Other users have been using this exe file with this one user having this issue.
I've forwarded this all to IT in hopes they an dig into it deeper than I can as I don't dare mess with registries and such.
Message 13 of 15
Actually, the value is not the same, it's slightly different - I was too tired to notice yesterday.
Could you please let us know if your IT finds the cause of the issue, it could help future users with the same issue.
Message 14 of 15
Well, no idea what happened.
A repair install did not fix the issue.
Had to completely uninstall and then reinstall the application to get the update (4.3) installed.
All is running fine now.
Message 15 of 15
***Update***
Found out the actual root cause of this...the user did not disable his anti-virus prior to running the install process.
Ugh...never even thought about it since it's (what I thought) common knowledge.
Another lesson that you can never, ever take things for granted.
