Install Autodesk Material Library 2016 - Base Image Library Failed Download Fail
I'm not very tech savy, and have looked through many, many different threads. I downloaded the MediumBaseLibrary2016, nothing changed. I'm trying to download my free trial because I'm a student that needs it for my class this term. I got my computer last year, so there should be no problem with being out of date. I'm so confused, please help.
If you can let me know what product you are using I can move you post to the appropriate forum
Discussion_Admin
Otto
Hello smithausVRXXC and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community...
Your installation is failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
