During installation of Autocad Map3D I got the following log:
2017/8/17:21:02:13 Planner Vijay Meena PLANNER-VIJAY-M === Setup started on PLANNER-VIJAY-M by Planner Vijay Meena ===
2017/8/17:21:02:13 Planner Vijay Meena PLANNER-VIJAY-M Path_Length: 154
2017/8/17:21:02:13 Planner Vijay Meena PLANNER-VIJAY-M Current Directory C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp
2017/8/17:21:02:13 Planner Vijay Meena PLANNER-VIJAY-M Launch
2017/8/17:21:02:27 Planner Vijay Meena PLANNER-VIJAY-M Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\Setup\AcSetup.dll
2017/8/17:21:02:27 Planner Vijay Meena PLANNER-VIJAY-M Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/8/17:21:03:38 Planner Vijay Meena PLANNER-VIJAY-M PageOpen LaunchDialog
2017/8/17:21:07:33 Planner Vijay Meena PLANNER-VIJAY-M PageOpen LicenseDialog
2017/8/17:21:07:37 Planner Vijay Meena PLANNER-VIJAY-M PageOpen ProductInfoDialog
2017/8/17:21:08:46 Planner Vijay Meena PLANNER-VIJAY-M PageOpen ProductSelectionDialog2
2017/8/17:21:10:32 Planner Vijay Meena PLANNER-VIJAY-M PageOpen FullProgressDialog
2017/8/17:21:10:32 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/8/17:21:11:02 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/8/17:21:11:02 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/8/17:21:11:28 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/8/17:21:11:28 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\d_vj\AppData\Local\Temp\vcredist_x86_2010.log
2017/8/17:21:11:39 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/8/17:21:11:39 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\d_vj\AppData\Local\Temp\vcredist_x64_2010.log
2017/8/17:21:11:46 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/8/17:21:11:46 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\d_vj\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/8/17:21:11:54 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/8/17:21:11:54 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\d_vj\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/8/17:21:11:56 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/8/17:21:11:56 Planner Vijay Meena PLANNER-VIJAY-M Installing DirectX Runtime: "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\DirectX\DXSETUP.exe" /silent
2017/8/17:21:12:20 Planner Vijay Meena PLANNER-VIJAY-M Install DirectX Runtime Succeeded
2017/8/17:21:12:20 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:12:48 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk Material Library 2016 Succeeded
2017/8/17:21:12:48 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:13:07 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/8/17:21:13:07 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® Material Library 2016 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:13:23 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® Material Library 2016 - Advanced Image Library Succeeded
2017/8/17:21:13:25 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:13:37 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk Content Service Succeeded
2017/8/17:21:13:37 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:13:40 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk Content Service Language Pack Succeeded
2017/8/17:21:13:40 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft SQL Server Native Client 11.0: IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:13:43 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft SQL Server Native Client 11.0 Succeeded
2017/8/17:21:13:44 Planner Vijay Meena PLANNER-VIJAY-M Installing AutoCAD Core: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:19:19 Planner Vijay Meena PLANNER-VIJAY-M Install AutoCAD Core Succeeded
2017/8/17:21:19:19 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk AutoCAD Map 3D 2016 Global: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\acadmap\acadmap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:24:49 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk AutoCAD Map 3D 2016 Global Succeeded
2017/8/17:21:24:51 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk AutoCAD Map 3D 2016 - English: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\en-us\AcadMap\AcadMapLP\AcadMapLP-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files (x86)\Autodesk\AutoCADMap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:25:42 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk AutoCAD Map 3D 2016 - English Succeeded
2017/8/17:21:25:45 Planner Vijay Meena PLANNER-VIJAY-M Installing AutoCAD Language Core: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\en-us\AcadMap\AcadLP\AcadLP-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:27:14 Planner Vijay Meena PLANNER-VIJAY-M Install AutoCAD Language Core Succeeded
2017/8/17:21:27:15 Planner Vijay Meena PLANNER-VIJAY-M Installing ACA & MEP 2016 Object Enabler: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\ACAOE\AcaOE-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:27:23 Planner Vijay Meena PLANNER-VIJAY-M Install ACA & MEP 2016 Object Enabler Succeeded
2017/8/17:21:27:25 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk AutoCAD Map 3D 2016: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\mapprivate\mapprivate-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:27:44 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk AutoCAD Map 3D 2016 Succeeded
2017/8/17:21:27:49 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® AutoCAD® Map 3D 2016: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\en-us\acadmap\AcadMapPS\AcadMapPS-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:29:16 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® AutoCAD® Map 3D 2016 Succeeded
2017/8/17:21:29:16 Planner Vijay Meena PLANNER-VIJAY-M Installing SketchUp Import plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:29:19 Planner Vijay Meena PLANNER-VIJAY-M Install SketchUp Import plug-in Succeeded
2017/8/17:21:29:25 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® Infrastructure Administrator 2016: TRANSFORMS="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\x64\en-us\admin\TBAdmin.mst;C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\Admin\TBAdmin-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Infrastructure Administrator 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:32:05 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® Infrastructure Administrator 2016 Succeeded
2017/8/17:21:32:09 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® Infrastructure Administrator 2016 Language Pack: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\_la6393.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Infrastructure Administrator 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:32:28 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® Infrastructure Administrator 2016 Language Pack Succeeded
2017/8/17:21:32:28 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2017/8/17:21:33:02 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2017/8/17:21:33:02 Planner Vijay Meena PLANNER-VIJAY-M Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/8/17:21:33:26 Planner Vijay Meena PLANNER-VIJAY-M Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/8/17:21:33:26 Planner Vijay Meena PLANNER-VIJAY-M Installing FARO LS 5.2.0.35213: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:33:54 Planner Vijay Meena PLANNER-VIJAY-M Install FARO LS 5.2.0.35213 Succeeded
2017/8/17:21:33:54 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® ReCap™: INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap 2016\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,.NET Framework Runtime 4.0,{66D83FE0-D798-4B38-86FE-FB48151E5AEF},;;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:36:49 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® ReCap™ Succeeded
2017/8/17:21:36:49 Planner Vijay Meena PLANNER-VIJAY-M Installing Exchange App Manager: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:36:57 Planner Vijay Meena PLANNER-VIJAY-M Install Exchange App Manager Succeeded
2017/8/17:21:36:57 Planner Vijay Meena PLANNER-VIJAY-M Installing Exchange Featured Apps plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:37:05 Planner Vijay Meena PLANNER-VIJAY-M Install Exchange Featured Apps plug-in Succeeded
2017/8/17:21:37:05 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® AutoCAD® Performance Reporting Tool: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:37:08 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® AutoCAD® Performance Reporting Tool Succeeded Reboot is required
2017/8/17:21:37:08 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk® BIM 360™ Add-in for AutoCAD® 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2016" SETUP_PACKAGECODE={7F0A8381-E3EA-4AAF-8D58-E0F989C32016} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4E808EB1-4F2B-4D17-A044-7F3EB374FD7D} ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:37:38 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk® BIM 360™ Add-in for AutoCAD® 2016 Succeeded
2017/8/17:21:37:39 Planner Vijay Meena PLANNER-VIJAY-M Installing A360 Desktop: TRANSFORMS="C:\Users\d_vj\AppData\Local\Temp\_AI29D1.tmp\x64\Components\Cloudsync\AdSync-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/17:21:38:34 Planner Vijay Meena PLANNER-VIJAY-M Install A360 Desktop Succeeded Reboot is required
2017/8/17:21:38:34 Planner Vijay Meena PLANNER-VIJAY-M Installing Autodesk Application Manager: "E:\Softwares\AUTODESK.AUTOCAD.MAP3D.V2016.WIN64-ISO\map16x64\map2016_x64\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2017/8/17:23:20:38 Planner Vijay Meena PLANNER-VIJAY-M Install Autodesk Application Manager Failed Failure is ignored, Result=1603
welcome @Anonymous!
Download the installation files from Autodesk Virtual Agent >>>click<<<, then start the installation from that local file(s), using option "start as administrator", disabled antivirus.
- alfred -
This manager has been retired and replaced with the Autodesk Desktop App. Is this the first time you're installing any Autodesk applications on this machine?
Mark Lancaster
& Autodesk Services MarketPlace Provider
